ThomM
We have been tasked with blocking DeepSeek on all campus resources. Unfortunately, keeping users from running DeepSeek models locally on their Macs isn’t as simple as making a Restricted Software title in Jamf Pro because the models aren’t actually apps.
What we can work with, however, is Ollama – the framework which DeekSeek models currently run under. If a user has installed Ollama, why not leverage that to check for the presence of DeepSeek LLMs?
Our first step is identifying it. The command ollama list will list all the LLMs a user has currently installed. If we grep those results for deepseek, we can make a little script-based Extension Attribute to identify Macs with DeepSeek LLMs present.
Next, make a Smart Computer Group for detections that looks something like this:
  • Criteria “DeepSeek Check” – is not – (blank)
  • AND
  • Criteria “DeepSeek Check” – is not – Not Detected
(You could probably get away with just one criteria where DeepSeek Check – is like – *deepseek* or do something with regex, but I did not test those.)
Next up, figure out your action plan.  We’ve been asked to do the following:
  • Alert the user and ask them to uninstall DeepSeek ASAP.
    • If they feel they need an exemption, direct them to contact our CISO.
  • If they ignore us, alert them again.
  • If they continue to ignore us, automatically remove it.
We’ve got three policies to make this happen, all scoped to our “DeepSeek Detected” Smart Computer Group.
  1. DeepSeek Uninstaller LaunchDaemon
    1. General
      1.          Trigger – Custom – KillDeepSeekDaemon
      2.          Frequency - Ongoing
    2. Script
      1.          DeepSeekRemovalDaemon.sh
        1. Writes a LaunchDaemon to call a policy which runs our auto-uninstall script after a set amount of time. I’ve given our users three days.
      2. DeepSeek Uninstaller
        1. General
          2.          Frequency – Ongoing
        2. Script
          1.          DeepSeekRemoval.sh
          2.          Takes advantage of the ollama rm command to remove all DeepSeek models.  It also checks for our LaunchDaemon and if found, boots it out and removes it.
        3. Maintenance
          1.          Update Inventory
        4. DeepSeek Alert
          1. General
            1.          Trigger – Login, Recurring Check-in
            2.          Frequency – Once every day
          2. Script
            1.          DeepSeekAlert.sh
JamfHelper is usually my go-to for user alerts, but it only supports two buttons.  I wanted three, so I chose osascript to pop up a series of dialogs. Please use whatever tool fits best for your org.
Our primary alert informs the user that DeepSeek has been detected on their Mac, is not permitted on our computers, and needs to be removed as soon as possible. It presents three buttons:
  • Do it for me
    • Triggers the KillDeepSeek policy.
    • Updates Inventory.
    • Thanks the user and tells them DeepSeek has been removed.
  • Do it myself
    • Thanks the user and advises them to update inventory from Self Service after removing DeepSeek.
    • Triggers the KillDeepSeekDaemon policy in case the user is trying to get around us.
  • No
    • Advises the user to contact our CISO (including CISO’s email address) to discuss an exemption ASAP. Also informs them that DeepSeek will be automatically uninstalled in three days if no action is taken.
    • Triggers the KillDeepSeekDaemon policy.
I should note this does not keep users from getting DeepSeek models through Ollama, but it does help us remediate it if they do.  It is also only effective while Ollama is the only way to run them.  We’ll have to keep an eye out for if – or realistically when – that changes and expand our methods to cover whatever the new hotness is.
5 Comments
Contributors
About the Author
I am the Mac Admin for the College of Social & Behavioral Sciences at the University of Arizona. This includes configuring, deploying, and maintaining our instances of JAMF Pro and Munki (working on retiring Munki) as well as management and maintenance of our Apple servers.
