Posted on 04-25-2025 02:12 AM
Anyone have any ideas how to find all devices that have no department or building data .i.e blank..
T.I.A
Posted on 04-25-2025 04:49 AM
If you know what the data should be, then you can create a smart group.
E.G. choose Building as Criteria, and Is Not, and add your first Building. Then repeat using OR for all of the rest of your Buildings. Whatever it then finds should no Building data. Handy tip for adding the Values, click on the 3 dots to the right of the Value box, it will show you the data you have set, and you can pick it from there too.
Building "Is Not" Value A
Or Building "Is Not" Value B
Or Building "Is Not" Value C
Buildings and Department will show up in Advanced Criteria when you make the smart group.
Posted on 04-25-2025 04:52 AM
Not an option as we have 12 buildings and around 200 departments.. I've now found the solution.
Posted on 04-25-2025 04:55 AM
If you're specifically looking for records that contain nothing (are totally empty of everything) then search for that...
Department is ____
or
Building is ____
Don't put anything in the fields, leave them totally blank.
Posted on 04-26-2025 06:27 AM
Just want to thumb this up. Totally the simplest way to go.
