View local/remote inventory with Swift Dialog interface
ScottEKendall
Hey Gang!  Back again...  This time, I have been digging into the JAMF API and exploring what can be done with it.  I came up with a script to view a users local computer record or view any JAMF record.  I really don't want our help desk team going into the server to retrieve info, so I came up with this.  This is only the start of what can be done, but it has been a learning experience to say the least.
Script can be found here: https://github.com/ScottEKendall/JAMF-Pro-Scripts/tree/main/ViewInventory
You can set this up via SS to have it display the local or remote option.  If you choose to view remote devices, you will be presented with an entry screen for serial # or hostname:
and the results screen of a remote inventory
If you choose to display the local record (no entry screen)
and finally, the script parameters to make it all happen
Let me know if you find it useful or any better ways to pull this info via API calls!
5 REPLIES 5
scottb
Honored Contributor
This looks pretty cool!  Have to check it out, but thank you for sharing!
Hey @ScottEKendall  - some really cool scripts in your git!
I actually have some needs and there's a few that will be very useful!  Thanks for sharing...
Scott
Jordy-Thery
This looks cool @ScottEKendall
scottb
Honored Contributor
@ScottEKendall  - just noticed a little issue on your git:
The "Remove Office" script is the same as the "Nuke Adobe".
I was wondering why it wasn't showing my Office apps when I ran it!  😀
Oh. Will have to take a look at that. Thanks.
Get Outlook for iOS<>
dletkeman
Keep up the good work @ScottEKendall !
