12:56 PM
03:55 AM
I've added a few applications to my VPP account which I can see in JSS but none of them appear to be Device assignable. Microsoft products in particular. I have to copy the URL from within App store and paste within VPP console. But even when I search using JSS I get the same thing.
Assuming this is correct, can someone suggest a free App I could use for testing?
If this isn't correct can someone tell me what I'm doing wrong?
Posted on 02-08-2018 01:34 PM
Most Microsoft apps look like they are labeled as device assignable.
Make sure to also select the box under the VPP tab to assign VPP content.
Posted on 02-08-2018 03:00 PM
Upon further investigation I found I was doing something wrong. Originally I was using the App Store on my Mac and copying the URL across (based on another forum post I found with searching issues in VPP).
I just tried doing the same thing but from an iPad. When I search in VPP now I get 3 options where as before I was only getting the one, which I had assumed was correct but was only for the Mac's.
The iOS version now automatically populates in JSS and I have the "Assign VPP Content" option.
Thanks bfrench for providing that little bit more info. pointed me to the solution.
Posted on 02-08-2018 02:31 PM
I'm assuming the screen grab above is from JSS 10. We're still running 9.101 hoping to upgrade soon though.
I see this when I "Search VPP Content"
I'm not seeing 'Microsoft OneNote' auto populate under Mobile Device Apps, so I've been adding a new 'App Store app or VPP store app' in this case I search for "Microsoft OneNote" I have 3 TABS at the top VPP Store Apps is blank. It's the "New App" that doesn't allow me to Assign VPP Content.
