Unable to Add AD Users to FV
VitorCostaUK
Had anyone ever experienced this issue when an AD user tries to log into a freshly built machine and I go to Security & Privacy > Filevault > Padlock (Enter Admin Creds) > then click on enable users , you should get a window with the users that can be enabled and you click on their name and they enter their password , however when I click on Enable users nothing shows up so I'm unable to add the users to FV
carlo_anselmi
@VitorCostaUK This is handy to assign missing SecureToken with a GUI, as always you first have to have a Secure Token holder user/password.
Token Rabbit
6 REPLIES 6
alexmcclements
Might be an issue with secure tokens, if the user doesn't have a secure token they can't be enabled for FileVault access.
https://travellingtechguy.eu/mojave-10-14-2-and-secure-tokens-it-works/
carlo_anselmi
Token Rabbit
This now happens when the user logs in.
VitorCostaUK
@carlo.anselmi Token Rabit worked a treat !
Thanks very much
jacob_evans
@carlo.anselmi Thanks, That's a rather handy tool :D
ooshnoo
Is there a script somewhere that allows assigning a token to any or all local users
