04:58 AM
05:55 AM
I am trying to set up a test server for trials. I get the JAVA jdk and the mysql database set up but when I go to install the JSS I get this dialog:
As I hope you can see, the server app window is visible in the background with 3 green dots on it so I have no idea what the dialog is trying to tell me. Do I need to have a FQDN for the server box for the JSS to recognize it or is there some other item I am missing?
Thanks much
Posted on 10-19-2015 06:38 AM
@kyoung if you are using Server 5.04 this is a know issue. I'm not sure if there is any workaround for the issue currently. I know there is a knowledge base article for installing a JDS with Server 5.04 but I am not sure about installing the JSS. I think the suggestion was to install an older version of the Server Application in order to get the JSS to install. Maybe someone else that knows differently can respond.
