Posted on 01-15-2025 10:53 AM
I have been busy at work lately with some more scripts! This one is a dual purpose app. If you pass the word "info" in the 4th parameter of the script it will inform the users of their laptop battery status, if you pass the word "fail" in the 4th parameter it will let them know that their capacity is below 'x' amount (You determine failure by a smartgroup)
#!/bin/zsh
# Written by: Scott E. Kendall
# Created: 2025-01-15
# Last Modified: 2025-01-15
# Prompt user if battery needs service
# Gobal "Common" variables
export PATH=/usr/bin:/bin:/usr/sbin:/sbin
JAMF_LOGGED_IN_USER=$3
BATTERY_CONDITION="${4:-"info"}"
LOGGED_IN_USER=$( scutil <<< "show State:/Users/ConsoleUser" | awk '/Name :/ && ! /loginwindow/ { print $3 }' )
USER_DIR=$( dscl . -read /Users/${LOGGED_IN_USER} NFSHomeDirectory | awk '{ print $2 }' )
OS_PLATFORM=$(/usr/bin/uname -p)
[[ "$OS_PLATFORM" == 'i386' ]] && HWtype="SPHardwareDataType.0.cpu_type" || HWtype="SPHardwareDataType.0.chip_type"
SYSTEM_PROFILER_BLOB=$( /usr/sbin/system_profiler -json 'SPHardwareDataType')
MAC_SERIAL_NUMBER=$( echo $SYSTEM_PROFILER_BLOB | /usr/bin/plutil -extract 'SPHardwareDataType.0.serial_number' 'raw' -)
MAC_CPU=$( echo $SYSTEM_PROFILER_BLOB | /usr/bin/plutil -extract "${HWtype}" 'raw' -)
MAC_HADWARE_CLASS=$( echo $SYSTEM_PROFILER_BLOB | /usr/bin/plutil -extract 'SPHardwareDataType.0.machine_name' 'raw' -)
MAC_RAM=$( echo $SYSTEM_PROFILER_BLOB | /usr/bin/plutil -extract 'SPHardwareDataType.0.physical_memory' 'raw' -)
FREE_DISK_SPACE=$(($( /usr/sbin/diskutil info / | /usr/bin/grep "Free Space" | /usr/bin/awk '{print $6}' | /usr/bin/cut -c 2- ) / 1024 / 1024 / 1024 ))
MACOS_VERSION=$( sw_vers -productVersion | xargs)
SW_DIALOG="/usr/local/bin/dialog"
SUPPORT_DIR="/Library/Application Support/GiantEagle"
IMAGE_ICON="SF=minus.plus.batteryblock, color=green, weight=normal"
SD_BANNER_IMAGE="${SUPPORT_DIR}/SupportFiles/GE_SD_BannerImage.png"
LOG_DIR="${SUPPORT_DIR}/logs"
ICON_FILES="/System/Library/CoreServices/CoreTypes.bundle/Contents/Resources/"
LOG_STAMP=$(echo $(/bin/date +%Y%m%d))
LOG_FILE="${LOG_DIR}/BatteryService.log"
SD_WINDOW_TITLE=" Battery Condition"
# Swift Dialog version requirements
SD_VERSION=$( ${SW_DIALOG} --version)
MIN_SD_REQUIRED_VERSION="2.3.3"
DIALOG_INSTALL_POLICY="install_SwiftDialog"
SUPPORT_FILE_INSTALL_POLICY="install_SymFiles"
SYSTEM_PROFILER_BATTERY_BLOB=$( /usr/sbin/system_profiler 'SPPowerDataType')
BatteryCondition=$(echo $SYSTEM_PROFILER_BATTERY_BLOB | grep "Condition" | awk '{print $2}')
BatteryCycleCount=$(echo $SYSTEM_PROFILER_BATTERY_BLOB | grep "Cycle Count" | awk '{print $3}')
BatteryCapacity=$(echo $SYSTEM_PROFILER_BATTERY_BLOB | grep "Maximum Capacity:" | awk '{print $3}')
BatteryCurrentCharge=$(echo $SYSTEM_PROFILER_BATTERY_BLOB | grep "State of Charge (%):" | awk '{print $NF}' )
BatteryCharging=$(echo $SYSTEM_PROFILER_BATTERY_BLOB | grep "Connected:" | sed 's/.*Connected: //')
BatteryChargingWattage=$(echo $SYSTEM_PROFILER_BATTERY_BLOB | grep "Wattage (W)" | sed 's/.*Wattage (W): //')
# Functions
function create_log_directory ()
# Ensure that the log directory and the log files exist. If they
# do not then create them and set the permissions.
# RETURN: None
# If the log directory doesnt exist - create it and set the permissions
[[ ! -d "${LOG_DIR}" ]] && /bin/mkdir -p "${LOG_DIR}"
/bin/chmod 755 "${LOG_DIR}"
# If the log file does not exist - create it and set the permissions
[[ ! -f "${LOG_FILE}" ]] && /usr/bin/touch "${LOG_FILE}"
/bin/chmod 644 "${LOG_FILE}"
function logMe ()
# Basic two pronged logging function that will log like this:
# 20231204 12:00:00: Some message here
# This function logs both to STDOUT/STDERR and a file
# The log file is set by the $LOG_FILE variable.
# RETURN: None
echo "${1}" 1>&2
echo "$(/bin/date '+%Y-%m-%d %H:%M:%S'): ${1}" | tee -a "${LOG_FILE}"
function check_swift_dialog_install ()
# Check to make sure that Swift Dialog is installed and functioning correctly
# Will install process if missing or corrupted
# RETURN: None
logMe "Ensuring that swiftDialog version is installed..."
if [[ ! -x "${SW_DIALOG}" ]]; then
logMe "Swift Dialog is missing or corrupted - Installing from JAMF"
install_swift_dialog
if ! is-at-least "${MIN_SD_REQUIRED_VERSION}" "${SD_VERSION}"; then
logMe "Swift Dialog is outdated - Installing version '${MIN_SD_REQUIRED_VERSION}' from JAMF..."
logMe "Swift Dialog is currently running: ${SD_VERSION}"
function install_swift_dialog ()
# Install Swift dialog From JAMF
# PARMS Expected: DIALOG_INSTALL_POLICY - policy trigger from JAMF
# RETURN: None
/usr/local/bin/jamf policy -trigger ${DIALOG_INSTALL_POLICY}
function check_support_files ()
[[ -x "${SD_BANNER_IMAGE}" ]] && /usr/local/bin/jamf policy -trigger ${SUPPORT_FILE_INSTALL_POLICY}
function create_infobox_message ()
# Swift Dialog InfoBox message construct
SD_INFO_BOX_MSG="## System Info ##\n"
#SD_INFO_BOX_MSG+="${MAC_CPU}<br>"
SD_INFO_BOX_MSG+="${MAC_SERIAL_NUMBER}<br>"
SD_INFO_BOX_MSG+="${MAC_RAM} RAM<br>"
SD_INFO_BOX_MSG+="${FREE_DISK_SPACE} GB Available<br>"
SD_INFO_BOX_MSG+="macOS ${MACOS_VERSION}<br>"
function welcomemsg ()
if [[ "${BATTERY_CONDITION:l}" == "info" ]]; then
Firstname="${(C)JAMF_LOGGED_IN_USER%%.*}"
messagebody="$Firstname, here is the current state of your laptop battery:<br><br>"
messagebody+="Condition: **${BatteryCondition}**<br>"
messagebody+="Current # of Cycles: **${BatteryCycleCount}**<br>"
messagebody+="Total Capacity Remain: **${BatteryCapacity}**<br>"
messagebody+="Battery Current Charge: **${BatteryCurrentCharge}**<br>"
messagebody+="Currently on Charger: **$BatteryCharging**<br>"
if [[ "$BatteryCharging" == "Yes" ]]; then
messagebody+="Charger Wattage: **${BatteryChargingWattage}W**<br>"
OVERLAY_ICON=
messagebody="Greetings ${Firstname}! This is an automated message from JAMF "
messagebody+="to let you know that the battery in your laptop is below acceptable"
messagebody+=" limits declared by Apple. The runtime while on battery and "
messagebody+="performance may be severly affected. Please raise a ticket with the"
messagebody+=" TSD to let them know that you received this message, and it is"
messagebody+=" recommended that you purchase a new laptop at this time."
OVERLAY_ICON="warning"
MainDialogBody="${SW_DIALOG} \
--message '${messagebody}' \
--icon '${IMAGE_ICON}' \
--overlayicon '${OVERLAY_ICON}' \
--height 420 \
--ontop \
--bannerimage '${SD_BANNER_IMAGE}' \
--bannertitle '${SD_WINDOW_TITLE}' \
--infobox '${SD_INFO_BOX_MSG}' \
--titlefont shadow=1 \
--moveable \
--button1text 'OK' \
--buttonstyle center"
# Show the dialog screen and allow the user to choose
eval "${MainDialogBody}" 2>/dev/null
function cleanup_and_exit ()
[[ -f ${JSON_OPTIONS} ]] && /bin/rm -rf ${JSON_OPTIONS}
[[ -f ${TMP_FILE_STORAGE} ]] && /bin/rm -rf ${TMP_FILE_STORAGE}
[[ -f ${DIALOG_COMMAND_FILE} ]] && /bin/rm -rf ${DIALOG_COMMAND_FILE}
# Main Program
autoload 'is-at-least'
check_support_files
welcomemsg
cleanup_and_exit
I have an automated trigger event to fire off the "fail" option if JAMF reports their battery failing, and the other method is available in Self service for the laptop users to check on their battery health.
Screenshot of the script parameter field:
Posted on 01-17-2025 06:17 AM
Nice, thanks for sharing!
Posted on 05-13-2025 08:50 AM
Hello Scott,
Quick question for you, when I run the policy, I always get a fail message. Is there a parameter I should be using to get it work?
Thanks,
Luis Javier
05-13-2025 08:54 AM - edited 05-13-2025 09:04 AM
Interesting...if you run it locally "sudo ./<appname>" does it work OK? You can also do "sudo zsh -x ./<appname>", but it will throw a ton of debug info at you... what OS are you on? the SYSTEM_PROFILER_BLOB is good for Sonoma or Sequoia...you might need to change it up for older OSes...
Posted on 05-13-2025 09:05 AM
I run it from it from Coderunner with sudo and I get the same error message. The only bugs that show up are for SwiftDialog being out of date.
Password:
Untitled 9.sh: command substitution: line 65: syntax error near unexpected token `)'
Untitled 9.sh: command substitution: line 65: `(){print Good ${argv[2+($1>11)+($1>18)]}} ${(%):-%D{%H}} morning afternoon evening'
Untitled 9.sh: line 84: ${(C)JAMF_LOGGED_IN_USER%%.*}: bad substitution
Untitled 9.sh: line 231: autoload: command not found
2025-05-13 12:02:43: Ensuring that swiftDialog version is installed...
Untitled 9.sh: line 135: is-at-least: command not found
Swift Dialog is outdated - Installing version '2.3.3' from JAMF...
2025-05-13 12:02:43: Swift Dialog is outdated - Installing version '2.3.3' from JAMF...
Untitled 9.sh: line 150: /usr/local/bin/jamf: No such file or directory
Untitled 9.sh: line 155: /usr/local/bin/jamf: No such file or directory
Posted on 05-13-2025 09:11 AM
Running it in Coderunner with Sudo still get the error message. Just shows messages for Swiftdialog.
Password:
