12-21-2024 03:51 AM - edited 06-16-2025 05:24 AM
We work in an area where users do not have admin rights, so I put together this script that allows them to remove apps from the main /Applications folder. You can control which required apps cannot be removed:
Link to my Repo: https://github.com/ScottEKendall/JAMF-Pro-Scripts/tree/main/AppDelete
#!/bin/zsh
# App Delete
# Written: Aug 3, 2022
# Last updated: Dec 21, 2024
# Gobal "Common" variables
LOGGED_IN_USER=$( scutil <<< "show State:/Users/ConsoleUser" | awk '/Name :/ && ! /loginwindow/ { print $3 }' )
USER_DIR=$( dscl . -read /Users/${LOGGED_IN_USER} NFSHomeDirectory | awk '{ print $2 }' )
SW_DIALOG="/usr/local/bin/dialog"
SUPPORT_DIR="/Library/Application Support/GiantEagle"
SD_BANNER_IMAGE="${SUPPORT_DIR}/SupportFiles/GE_SD_BannerImage.png"
LOG_DIR="${SUPPORT_DIR}/logs"
LOG_FILE="${LOG_DIR}/AppDelete.log"
# have to "pad" the text title to accomodate for the hardcoded banner image we currently display, this will make it more centered on the screen (5 spaces)
BANNER_TEXT_PADDING=" "
SD_INFO_BOX_MSG=""
SD_WINDOW_TITLE="${BANNER_TEXT_PADDING}Remove Applications"
# Create temp files to store the JSON blob display options and for the choosen deleted items
JSON_OPTIONS=$(mktemp /private/tmp/AppDelete.XXXXX)
TMP_FILE_STORAGE=$(mktemp /private/tmp/AppDelete.XXXXX)
# The follow array lists the apps that the users are not allowed to remove. If the apps show up in the list, they do not appear in the list of apps that can be deleted
MANAGED_APPS=(
"Company Portal"
"Falcon"
"Jamf Connect"
"Self Service"
"ZScaler")
# Swift Dialog version requirements
[[ -e "${SW_DIALOG}" ]] && SD_VERSION=$( ${SW_DIALOG} --version) || SD_VERSION="0.0.0"
MIN_SD_REQUIRED_VERSION="2.3.3"
DIALOG_INSTALL_POLICY="install_SwiftDialog"
typeset -a FILES_LIST
typeset HARDWARE_ICON
typeset messagebody
typeset MainDialogBody
# Global Functions
function create_log_directory ()
# Ensure that the log directory and the log files exist. If they
# do not then create them and set the permissions.
# RETURN: None
# If the log directory doesnt exist - create it and set the permissions
if [[ ! -d "${LOG_DIR}" ]]; then
/bin/mkdir -p "${LOG_DIR}"
/bin/chmod 755 "${LOG_DIR}"
# If the log file does not exist - create it and set the permissions
if [[ ! -f "${LOG_FILE}" ]]; then
/usr/bin/touch "${LOG_FILE}"
/bin/chmod 644 "${LOG_FILE}"
function logMe ()
# This function logs both to STDOUT/STDERR and a file
# The log file is set by the $LOG_FILE variable.
# RETURN: None
echo "${1}" 1>&2
echo "$(/bin/date '+%Y%m%d %H:%M:%S'): ${1}\n" >> "${LOG_FILE}"
function alltrim ()
echo "${1}" | /usr/bin/xargs
function check_swift_dialog_install ()
# Check to make sure that Swift Dialog is installed and functioning correctly
# Will install process if missing or corrupted
# RETURN: None
logMe "Ensuring that swiftDialog version is installed..."
if [[ ! -x "${SW_DIALOG}" ]]; then
logMe "Swift Dialog is missing or corrupted - Installing from JAMF"
install_swift_dialog
if ! is-at-least "${MIN_SD_REQUIRED_VERSION}" "${SD_VERSION}"; then
logMe "Swift Dialog is outdated - Installing version '${MIN_SD_REQUIRED_VERSION}' from JAMF..."
logMe "Swift Dialog is currently running: ${SD_VERSION}"
function install_swift_dialog ()
# Install Swift dialog From JAMF
# PARMS Expected: DIALOG_INSTALL_POLICY - policy # from JAMF
# RETURN: None
/usr/local/bin/jamf policy -trigger ${DIALOG_INSTALL_POLICY}
# Functions
function cleanup_and_exit ()
[[ -f ${JSON_OPTIONS} ]] && /bin/rm -rf ${JSON_OPTIONS}
[[ -f ${TMP_FILE_STORAGE} ]] && /bin/rm -rf ${TMP_FILE_STORAGE}
function create_filelist_json_blob ()
# Swift Dialog BLOB file for prompts
echo '{
"overlayicon" : "/System/Applications/App Store.app",
"icon" : "'SF=trash.fill, color=black, weight=light'",
"message" : "Please choose the application(s) that you want to remove from your system",
"bannerimage" : "'"${SD_BANNER_IMAGE}"'",
"bannertitle" : "'"${SD_WINDOW_TITLE}"'",
"messagefont" : "size=18",
"titlefont" : "shadow=1 size=28",
"moveable" : "true",
"ontop" : "true",
"button1text" : "Next",
"checkboxstyle" : {
"style" : "switch",
"size" : "regular" },
"button2text" : "Cancel",
"messageposition" : "top",
"height" : "750",
"width" : "920",' > ${JSON_OPTIONS}
function build_file_list_array ()
typeset -a tmp_array
typeset saved_IFS=$IFS
IFS=$'\n'
FILES_LIST=( $(/usr/bin/find /Applications/* -maxdepth 0 -type d -iname '*.app' ! -ipath '*Contents*' | /usr/bin/sort -f | /usr/bin/awk -F '/' '{ print $3 }' | /usr/bin/awk -F '.app' '{ print $1 }'))
${IFS+':'} unset saved_IFS
# remove the items from array that are in the Managed apps array
for i in "${MANAGED_APPS[@]}"; do FILES_LIST=("${FILES_LIST[@]/$i}") ; done
# Add only the non-empty items into the tmp_array
for i in "${FILES_LIST[@]}"; do [[ -n "$i" ]] && tmp_array+=("${i}") ; done
# copy the newly created array back into the working array
FILES_LIST=(${tmp_array[@]})
function construct_display_list ()
# Construct the Swift Dialog display list based on files that can be deleted
if [[ ${#FILES_LIST[@]} -ne 0 ]]; then
# Construct the fils(s) list
echo ' "checkbox" : [' >> ${JSON_OPTIONS}
echo '{"label" : "'"${i}"'", "checked" : false, "disabled" : false, "icon" : "/Applications/'${i}'.app" },' >> "${JSON_OPTIONS}"
echo ']}' >> "${JSON_OPTIONS}"
chmod 644 "${JSON_OPTIONS}"
function choose_files_to_delete ()
MainDialogBody="${SW_DIALOG} \
--helpmessage 'Choose which applications you want to remove. \nThey can be installed again from Self Service.' \
--jsonfile '${JSON_OPTIONS}' \
--infobox '${SD_INFO_BOX_MSG}' \
--quitkey 0 \
--json"
# Show the dialog screen and allow the user to choose
tmp=$(eval "${MainDialogBody}")
buttonpress=$?
# User hit cancel so exit the app safely
[[ ${buttonpress} -eq 2 || ${buttonpress} -eq 10 ]] && cleanup_and_exit
# Strip out the files that they did not choose
echo $tmp | grep -v ": false" > "${TMP_FILE_STORAGE}"
function read_in_file_contents ()
messagebody=""
while read -r line; do
name=$( echo $(alltrim "${line}") | /usr/bin/awk -F " : " '{print $1}' | tr -d '"')
[[ -e "/Applications/${name}.app" ]] && messagebody+="- ${name} \n"
done < "${TMP_FILE_STORAGE}"
function show_final_delete_prompt ()
--message 'Are you sure you want to delete these applications?\n\n${messagebody}' \
--icon "SF=trash.fill,color=black,weight=light" \
--height 500 \
--ontop \
--bannerimage '${SD_BANNER_IMAGE}' \
--bannertitle '${SD_WINDOW_TITLE}' \
--button1text 'Delete' \
--button2text 'Cancel' \
--buttonstyle center "
buttonpress=$?
# User wants to continue, so delete the files
[[ ${buttonpress} -eq 0 ]] && delete_files
# user choose to exit
[[ ${buttonpress} -eq 2 ]] && cleanup_and_exit
function delete_files ()
name=$( echo $(alltrim "${line}" ) | /usr/bin/awk -F " : " '{print $1}' | tr -d '"')
if [[ -n "${name}" ]] && [[ -e "/Applications/${name}.app" ]]; then
/bin/rm -rf "/Applications/${name}.app"
logMe "Removed application: ${name}"
function show_completed_prompt ()
--message 'The following application(s) have been deleted.<br><br>${messagebody}\n\nIf you need to delete more files, you can choose \"Run Again\" below.' \
--ontop \
--overlayicon 'SF=checkmark.circle.fill,color=auto,weight=light,bgcolor=none' \
--width 920 \
--quitkey 0 \
--button1text 'OK' \
--button2text 'Run Again'"
buttonpress=$?
[[ ${buttonpress} -eq 0 || ${buttonpress} -eq 10 ]] && cleanup_and_exit
# Auto Load Functions
autoload 'is-at-least'
# Start of Main Script
while true; do
# Display a final warning with the flles they chose
cleanup_and_exit
Posted on 12-24-2024 10:39 AM
Sounds pretty cool, I'll have to test it out.
Posted on 12-26-2024 02:17 AM
Tested and working pretty well. Thank you
12-30-2024 06:30 AM - edited 12-30-2024 11:11 AM
Works like a charm.
