Posted on 05-21-2025 07:24 AM
Hello All,
I want to deploy updates to Ipads in non business hours probably between 1-4 AM, how can i achieve that. I am new to JAMF
Thanks in advance
Posted on 05-21-2025 07:43 AM
You can set deployment date and time in the policy so that it's available between the time that you want it to go out. The policy is going to apply according to the device's local time by default, so you don't really need to work about time zones.
Since you're new to Jamf, you should definitely take the self-paced Jamf 100 course to help you get started with the basics like this.
Posted on 05-21-2025 07:44 AM
Thank you
