Posted on 07-08-2024 06:32 PM
I found this script very useful and extracting the list of application usage in the Smart Group.
# This script uses the api to gather all serial numbers of a computer group and then gathers application usage data for that mac.
# each entry contains User data so, multiple lines will exist for each serial. one for each application.
# exported report is stored in a coma sperated spreadsheet.
# Please see end of script for terms
# Environment Specific Variables can be left blank if passing parameters from jamf
# hardcode here for testing
api_user=""
api_pass=""
jamf_url=""
# A Jamf Pro computer group (static or smart) that contains the client for which you want a report
group_name=''
# Number of days in report (using today as the end date...)
days=
# Check for passed parameters from jamf
if [ "$4" != "" ]; then
api_user=$4
if [ "$5" != "" ]; then
api_pass=$5
if [ "$6" != "" ]; then
jamf_url=$6
if [ "$7" != "" ]; then
group_name=$7
if [ "$8" != "" ]; then
days=$8
# Location of jamfHelper
jamfHelper="/Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper"
# For testing only if you have a test JSS with a self signed SSL cert...
# Set security='' for normal use. Set security='--insecure' for testing
security=''
#security='--insecure'
# URL encode function
urlencode() {
old_lc_collate=$LC_COLLATE
LC_COLLATE=C
local length="${#1}"
for (( i = 0; i < length; i++ )); do
local c="${1:i:1}"
case $c in
[a-zA-Z0-9.~_-]) printf "$c" ;;
*) printf '%%%02X' "'$c" ;;
esac
LC_COLLATE=$old_lc_collate
# URL encode the group name
group_name=$( urlencode "$group_name" )
# Pretty file name
filename="Application Usage Report - $days day "
# Today's date minus the days
start_date=$(date -j -v-${days}d +"%Y"-"%m"-"%d")
# Today's date
end_date=$(date +"%Y-%m-%d")
# Timestamp for filename
timestamp=$(date +"%Y-%m-%d-%H%M%S")
# Getting the Bearer token
jamfTokenCurl=$(curl -s -u "$api_user:$api_pass" "$jamf_url/api/v1/auth/token" -X POST)
jamfBearerToken=$(echo "$jamfTokenCurl" | jq -r .token)
# If you want, this dialog box will let the user know what's about to happen
buttonClicked=$("$jamfHelper" \
-windowType utility \
-title "Application Usage Report" \
-heading "Please click OK to build the report." \
-description "This process may take a few minutes depending on how many computers are in the report. We'll let you know when we're finished." \
-button1 "Okay" \
-defaultButton 1 \
-icon "/System/Library/CoreServices/CoreTypes.bundle/Contents/Resources/AlertNoteIcon.icns")
# Build the API path to the smartgroup
api_path="JSSResource/computergroups/name/${group_name}"
# Get the currently logged in user for the output file path
loggedInUser=$(scutil <<< "show State:/Users/ConsoleUser" | awk '/Name :/ { print $3 }')
loggedInUserHome=$(dscl . read /Users/$loggedInUser NFSHomeDirectory | cut -d' ' -f2-)
# Getting Serial Numbers
echo "Getting a list of devices in Jamf Pro group. "
URL="${jamf_url}/${api_path}"
responseXML=$(curl ${security} --silent --show-error --write-out "\n%{http_code}" \
--header "Authorization: Bearer ${jamfBearerToken}" \
--header "Accept: text/xml" "${URL}")
HTTP_Status=$(echo "$responseXML" | tail -1)
responseXML=$(echo "$responseXML" | sed \$d)
echo "HTTP_Status : $HTTP_Status"
/bin/echo -n "HTTP Status Code: $HTTP_Status : "
if [[ $HTTP_Status = "200" ]]; then
echo '[OK]'
elif [[ $HTTP_Status = "400" ]]; then
echo "[error] Invalid API request"
exit 1
echo "[error] API could not return the group information. "
echo "$responseXML"
exit 1
serialnumbers=($(echo "$responseXML" | xsltproc /tmp/stylesheet.xslt -))
echo "Serial number list : ${serialnumbers[@]}"
device_count=${#serialnumbers[@]}
touch /tmp/export.csv
# Write the header values of each column
echo "Full Name,Username,Position,Department,Building,Room,Email Address,Model,Serial Number,App Name,Version Number,Minutes in Forground,Minutes Open" > /tmp/export.csv
for serial in "${serialnumbers[@]}"; do
echo "Requesting details for device serial number : ${serial}"
api_device_path="JSSResource/computers/serialnumber/$serial"
location_data=$(curl ${security} --silent --show-error \
--header "Accept: text/xml" "$jamf_url/$api_device_path")
username=$(echo $location_data | /usr/bin/awk -F'<username>|</username>' '{print $2}')
realname=$(echo $location_data | /usr/bin/awk -F'<realname>|</realname>' '{print $2}')
email_address=$(echo $location_data | /usr/bin/awk -F'<email_address>|</email_address>' '{print $2}')
position=$(echo $location_data | /usr/bin/awk -F'<position>|</position>' '{print $2}')
department=$(echo $location_data | /usr/bin/awk -F'<department>|</department>' '{print $2}')
room=$(echo $location_data | /usr/bin/awk -F'<room>|</room>' '{print $2}')
building=$(echo $location_data | /usr/bin/awk -F'<building>|</building>' '{print $2}')
model=$(echo $location_data | /usr/bin/awk -F'<model>|</model>' '{print $2}')
echo "\$username : \"${username}\""
echo "\$realname : \"${realname}\""
echo "\$email_address : \"${email_address}\""
echo "\$position : \"${position}\""
echo "\$department : \"${department}\""
echo "\$room : \"${room}\""
echo "\$building : \"${building}\""
echo "\$model : \"${model}\""
api_path="JSSResource/computerapplicationusage/serialnumber/$serial/${start_date}_${end_date}"
xmlResponse=$(curl ${security} --silent --show-error \
--header "Accept: text/xml" "$jamf_url/$api_path")
cat << EOF > /tmp/stylesheet.xslt
<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
<xsl:output method="text"/>
<xsl:template match="/">
<xsl:for-each select="computer_application_usage/usage/apps/app">
<xsl:text>${realname//,}</xsl:text>
<xsl:text>,</xsl:text>
<xsl:text>${username//,}</xsl:text>
<xsl:text>${position//,}</xsl:text>
<xsl:text>${department//,}</xsl:text>
<xsl:text>${room//,}</xsl:text>
<xsl:text>${building//,}</xsl:text>
<xsl:text>${email_address//,}</xsl:text>
<xsl:text>${model//,}</xsl:text>
<xsl:text>$serial</xsl:text>
<xsl:value-of select="name"/>
<xsl:value-of select="version"/>
<xsl:value-of select="foreground"/>
<xsl:value-of select="open"/>
<xsl:text>
</xsl:text>
</xsl:for-each>
</xsl:template>
</xsl:stylesheet>
EOF
usageData=$(echo "$xmlResponse" | xsltproc /tmp/stylesheet.xslt -)
if [[ -z "$usageData" ]]; then
echo "No application usage data found for serial number ${serial}."
echo "$usageData" >> /tmp/export.csv
# Output file path
outputFilePath="${loggedInUserHome}/Desktop/${filename} - ${timestamp}.csv"
# Move the file to the user's desktop
mv /tmp/export.csv "$outputFilePath"
# Notify the user that the report is complete
"$jamfHelper" \
-heading "Report Complete" \
-description "The application usage report has been saved to your Desktop." \
-button1 "OK" \
-defaultButton 1 \
# Invalidate the Bearer token
curl -s -H "Authorization: Bearer ${jamfBearerToken}" -X POST "${jamf_url}/api/v1/auth/invalidate-token"
echo "Done! Check ${outputFilePath} for the report."
Posted on 03-19-2025 01:10 PM
Thanks for putting thr work in here.
I'm attempting to use this and I'm getting a "Getting a list of devices in Jamf Pro group.
HTTP_Status : 401
HTTP Status Code: 401 : [error] API could not return the group information." error
Any suggestions?
Posted on 06-16-2025 06:38 AM
it looks like it is using the classic API, so be sure to use the correct credentials when authenticating for the calls...
