06:59 AM
09:17 AM
We are trying to push out a script that deletes all printers. That part of it works just fine.
We use the following:
# Get all printers and remove them
# Log printer names
echo "Removing all printers..."
for printer in `lpstat -p | awk '{print $2}'`
do
echo $printer >> "/Library/LOGGINGFOLDER/$logname"
lpadmin -x $printer
We use logging in case we need to reinstall anything later.
Problem is that when there aren't any printers to delete then the exit code is 1 and an error notification is triggered. How do I test if printers are installed before continuing? else would be exit with code 0 (success).
Thanks for the help!
Posted on 09-17-2019 07:24 AM
Simplest thing is to store the results of lpstat -p | awk '{print $2}'
into a variable first in the script. Then have an if/then block that tests to see if the variable is populated with data or not. It would be empty if no printers are installed. If it's not a null value, then proceed with the removals.
Installed_Printers=$(/usr/bin/lpstat -p | awk '{print $2}')
if [ -n "$Installed_Printers" ]; then
for printer in $Installed_Printers; do
echo $printer >> "/Users/mikem/Desktop/logfile1.log"
/usr/sbin/lpadmin -x $printer
echo "No printers installed"
Posted on 09-17-2019 08:22 AM
Thanks! That did the trick!
