08:34 AM
06:57 AM
JSS 9.100, RHEL6. HTTP distribution point and failover
For the past few weeks (2-3) we've been seeing random policy errors coming in. All errors are
The network connection was interrupted while downloading the package from http://<SERVER/PACKAGE>. Attempting to reconnect... Downloading http://<SERVER/PACKAGE>... Error: <PACKAGE> is not available on the HTTP server.
It seems to happen mainly with laptops over wireless but we've also been seeing it happen with some wired clients now. The odd thing is that we'll check the logs and notice that the user would run that policy 2-3 more times after the failed attempt and it would succeed every subsequent time (below seems to be a more excited user).
It's not just self service, it's also recurring policies. It's also not happening on one specific network/subnet, it seems to be very random.
Anyone have any ideas or suggestions?
Posted on 09-07-2017 09:16 AM
We've also had this issue since upgrading to the latest version. Packages are stated as not being present via http...
Posted on 09-07-2017 11:22 AM
Put me in the I've seen this ghost too, category. Happens mostly when/while my New Build process is running. We run thin images, stuff triggers as soon as the machine is joined to the JSS. I moved away from the Enrollment Complete trigger for the bulk of my package installs and have the "Login" trigger. Anyway, I see this too, annoy's the crap outta me..
Posted on 09-07-2017 12:14 PM
we get this quite a lot, but as HTTP downloads self resume it usually fixes itself. We put in the HTTP distros, running on SMB distros, to improve reliability. We still get it on a new RHEL that only does distribution and has no jss or anything else on.
Posted on 09-08-2017 09:41 AM
Funny enough, caching seems to work flawlessly...
Posted on 09-08-2017 01:15 PM
Spoke too soon. Caching also does this sometimes. Just not as much.
Very frustrating!
Posted on 09-08-2017 02:22 PM
Are these packages flat packages?
Posted on 09-08-2017 03:56 PM
@tlarkin It's DMGs and PKGs.
Posted on 09-08-2017 05:38 PM
I guess my next question would be, when this happens can you curl
down the package manually, or copy the URL into a browser and download?
Posted on 09-10-2017 07:00 AM
It downloads fine.
We've been trying on our different subnets that show errors and it seems to work fine every time.
It doesn't seem like an issue with networking because the same policy will have 1 error (on subnet 10.48.x.x) and 50 successes on the same subnet.
We thought it was an issue with the user not letting the policy finish by either closing the computer or disconnecting but if we flush the policy on the machine it'll error again and we can repeat that and it might succeed.
Nothing on our distro point has changed either, it's been working fine for over a year now.
Posted on 09-12-2017 11:14 AM
I definitely see this as well. I just assumed it was from students closing their laptops between classes. Usually flushing errors will fix the issue. You can curl the file fine and copy/paste the url and it downloads fine.
Posted on 09-12-2017 02:58 PM
@Asnyder We're thinking that as well, we typically don't push out to student laptops because of this but we switched AVs and need to get it out.
I wonder if power nap will cause a machine to check in and fail...
Posted on 09-22-2017 05:58 AM
Still getting these randomly throughout the day. I opened a ticket with jamf but since I cannot replicate it on-demand with a verbose policy run the ticket went stale and closed. Not really sure what to do, it's very frustrating for our users.
Posted on 09-22-2017 10:15 AM
@jmahlman We still see it as well. I just try to be proactive about flushing errors. Sometimes that can be a hard task with only two in our district's IT department.
Posted on 10-02-2017 07:53 AM
We haven't seen any errors since we upgraded to 9.101. Not sure if it's because things are dying down here or because it's actually fixed.
Posted on 10-23-2017 03:27 PM
I'm seeing it on 9.101 calling a manually triggered package install policy from a Self Service policy. Not all machines do it but I have a test laptop that I can reproduce it almost 100% of the time.
Posted on 10-25-2017 06:55 AM
Cough...cough...loadBalanceYourRHL6distributionPoints...cough...cough
Posted on 01-12-2018 12:01 PM
So I'm re-opening my post, we're seeing tons of failures again, even when it's a small amount of policies being run. It seems to happen mostly with self service policies.
Log 1: Self service policy, laptop on wireless:
Actions from policy log:
[STEP 1 of 9]
Executing Policy Xerox Printer Drivers and Utilities
[STEP 2 of 9]
Downloading HP-PrinterDrivers-3.0.pkg...
Downloading http://[DISTRO1]:8008/CasperShare/Packages/HP-PrinterDrivers-3.0.pkg...
Could not connect to the HTTP server to download HP-PrinterDrivers-3.0.pkg.
Retrying using distribution point [DISTRO2]...
Resuming download of http://[DISTRO2]/CasperShare/Packages/HP-PrinterDrivers-3.0.pkg...
Error: Could not connect to the HTTP server to download HP-PrinterDrivers-3.0.pkg.
[STEP 3 of 9]
Downloading Pharos-Popup-9.0.8.pkg...
Downloading http://[DISTRO1]:8008/CasperShare/Packages/Pharos-Popup-9.0.8.pkg...
Could not connect to the HTTP server to download Pharos-Popup-9.0.8.pkg.
Downloading http://[DISTRO2]/CasperShare/Packages/Pharos-Popup-9.0.8.pkg...
Error: Could not connect to the HTTP server to download Pharos-Popup-9.0.8.pkg.
[STEP 4 of 9]
Downloading http://[DISTRO1]:8008/CasperShare/Packages/Xerox-3300MFP-Driver.dmg...
Could not connect to the HTTP server to download Xerox-3300MFP-Driver.dmg.
Downloading http://[DISTRO2]/CasperShare/Packages/Xerox-3300MFP-Driver.dmg...
Error: Could not connect to the HTTP server to download Xerox-3300MFP-Driver.dmg.
[STEP 5 of 9]
Downloading Xerox-Phaser-3260-Driver-1.02.pkg...
Downloading http://[DISTRO1]:8008/CasperShare/Packages/Xerox-Phaser-3260-Driver-1.02.pkg...
Could not connect to the HTTP server to download Xerox-Phaser-3260-Driver-1.02.pkg.
Downloading http://[DISTRO2]/CasperShare/Packages/Xerox-Phaser-3260-Driver-1.02.pkg...
Error: Could not connect to the HTTP server to download Xerox-Phaser-3260-Driver-1.02.pkg.
[STEP 6 of 9]
Downloading Xerox-PL-Print-Driver-2.0.15.pkg...
Downloading http://[DISTRO1]:8008/CasperShare/Packages/Xerox-PL-Print-Driver-2.0.15.pkg...
Could not connect to the HTTP server to download Xerox-PL-Print-Driver-2.0.15.pkg.
Downloading http://[DISTRO2]/CasperShare/Packages/Xerox-PL-Print-Driver-2.0.15.pkg...
The network connection was interrupted while downloading the package from http://[DISTRO2]/CasperShare/Packages/Xerox-PL-Print-Driver-2.0.15.pkg. Attempting to reconnect...
Resuming download of http://[DISTRO2]/CasperShare/Packages/Xerox-PL-Print-Driver-2.0.15.pkg...
Verifying package integrity...
Installing Xerox-PL-Print-Driver-2.0.15.pkg...
Successfully installed Xerox-PL-Print-Driver-2.0.15.pkg.
[STEP 7 of 9]
Downloading Xerox-Print-Driver-3.68.0.pkg...
Downloading http://[DISTRO1]:8008/CasperShare/Packages/Xerox-Print-Driver-3.68.0.pkg...
Could not connect to the HTTP server to download Xerox-Print-Driver-3.68.0.pkg.
Resuming download of http://[DISTRO2]/CasperShare/Packages/Xerox-Print-Driver-3.68.0.pkg...
Installing Xerox-Print-Driver-3.68.0.pkg...
Successfully installed Xerox-Print-Driver-3.68.0.pkg.
[STEP 8 of 9]
[STEP 9 of 9]
Log 2: Self service policy, hard wired iMac.
[STEP 1 of 6]
Executing Policy Adobe Acrobat DC 18.0
[STEP 2 of 6]
Running script removeJAMFdownloadFolder.sh...
Script exit code: 0
Script result:
[STEP 3 of 6]
Downloading http://[DISTRO1]:8008/CasperShare/Packages/Adobe_Acrobat_DC_18.0_Install.pkg.zip...
Installing Adobe_Acrobat_DC_18.0_Install.pkg.zip...
Installation failed. The installer reported: installer: Package name is Adobe_Acrobat_DC_18.0
installer: Installing at base path /
installer: The install failed (The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.)
Downloading http://[DISTRO2]/CasperShare/Packages/Adobe_Acrobat_DC_18.0_Install.pkg.zip...
The network connection was interrupted while downloading the package from http://[DISTRO2]/CasperShare/Packages/Adobe_Acrobat_DC_18.0_Install.pkg.zip. Attempting to reconnect...
Error: Adobe_Acrobat_DC_18.0_Install.pkg.zip is not available on the HTTP server.
[STEP 4 of 6]
[STEP 5 of 6]
Inventory will be updated when all queued actions in Self Service are complete.
[STEP 6 of 6]
The last log is from our Adobe install policy which works fine for many users but we still see a lot of errors like this. Even though this machine has several failures, the application is still installed.
Posted on 01-12-2018 12:16 PM
Oh and we have random load balancing enabled. Both DP servers are more than capable of handling the loads.
Posted on 10-17-2018 07:57 AM
I'm seeing this as well. FWIW, I have an AWS cloud distro as master. I've had to actually re-upload certain packages for days in a row.
Posted on 10-17-2018 08:30 AM
been getting this for the last 2 weeks or so. Jamf support was saying that their cloud storage was partially to blame. Just got this error today.
