Posted on 07-29-2021 09:52 AM
Has anyone had any success getting Parallels to use PXE boot so we can use an SCCM image?
Posted on 07-29-2021 10:36 AM
This seems like a wrong place to post something about windows, but I have been able to do this before with SCCM.
Posted on 03-20-2025 01:41 PM
I have Windows VMs on my Parallels for Mac. I use only Mac hardware. This is a valid question to be posted here.
Posted on 07-29-2021 10:53 AM
can you share details how you accomplished this? we have several mac users that use parallels because some of their engineering apps are only windows based. this would allow us to handle licensing much easier than a manual windows install.
Posted on 07-29-2021 11:04 AM
I would recommend using VMWare Fusion as they have formal support for all of this. Though keep in mind you can only run Windows in a VM on Intel Macs. Microsoft does not sell product keys or licensing beyond that of OEM for Windows for ARM.
In my environment I actually pulled the plug on Windows VM's early last year. Way too much hassle and the Windows team never wants to support them. If someone who has a Mac needs a Windows instance we point them to our VDI solutions. Local VM's are not used a frequently as they should be and are off most of the time, they love to have problems with SCCM. Nothing like a "urgent" ticket for a VM that has not been turned on in 6 months that the person needs now for some "critical" issue they are working on.
Posted on 02-07-2024 09:25 AM
I know this thread is from almost 3 years ago, but currently you CAN run Windows VMs on Apple Silicon Macs. I have an M1 Mac Mini running Parallels with a Windows 11 VM.
Posted on 03-20-2025 01:44 PM
maybe that was true at some point, but not now. I have licensed multiple Windows 11 VMs on ARM64 Macs with Parallels. I currently have a licensed Windows 11 VM on my ARM64 Mac that i use regularly.
Posted on 03-20-2025 01:45 PM
i just noticed i already responded to this a year ago with the updated information. sorry for the double post.
Posted on 07-29-2021 11:00 AM
I'd be interested to see if anyone has a good work flow for this, especially since so many of us also manage Windows Environments I'm sure someone has done it.
Looks like Parallels does not offer network boot by default, you have to change settings for it. I wonder what would happen if you tossed the boot media on a flash drive and told Parallels to boot off of that. It should point to the PXE server when the installer loads to get everything. Technically this is not network boot. I do know you cannot used shared networking as PXE will not work with that, you need bridged.
This link has a promising guide, I am kinda interested to try but I am on the VPN and our PXE servers are not accessible through our VPN gateways.
Posted on 07-29-2021 11:03 AM
Yes but it took a bit of messing about. It was about 2 years ago so an older version of Parallels. I was only able to get it to work if I wiped an existing windows VM or clone one and rename it. In other words I could not create a new VM just pxe booting.
Parallels part
1.The main point is you need an existing VM so the Mac address can be to imported into SCCM. I did try to create a blank VM but it never worked until I tried to wipe a working VM or clone.
SCCM part
Posted on 07-29-2021 10:27 PM
pxe booting will work if you give parallels vm a real ip (not shared). Otherwise what I do is just create a sccm pxe boot iso and have parallels boot that.
