01:14 PM
06:35 AM
VMware Fusion 11.5.5 now has 21 files in the application bundle with attached xattrs which are not preserved if you use Composer to create a .pkg installer, or when running the AutoPkg recipe for packaging VMware Fusion 11. Attempting to run a VM without those xattrs present will fail with a broken pipe error.
To work around this for Composer you can compress the VMware Fusion.app bundle, the create an installer .pkg to drop the .zip file in a temporary location and use ditto
to extract the app into /Applications
which will preserve the xattrs. The fix for the AutoPkg recipe will require a change to one of the AutoPkg components.
Posted on 05-30-2020 01:21 PM
I was dealing with something similar last week. It seems the solution is blogged here: https://carlashley.com/2018/11/03/preserving-xattr-with-pkgbuild/
If you want to use composer, rather than CLI tools then you'll have to do an FR request for this as an option with Composer. I'll happily upvote.
Posted on 05-30-2020 01:34 PM
@franton Thanks for the reference, I added it to the conversation in #autopkg on Mac Admis Slack. I'll get that FR created sometime this evening
Posted on 05-30-2020 02:08 PM
FR created: Composer needs to support xattrs
Posted on 05-30-2020 06:15 PM
You can also use munkipkg to package VMware Fusion 11.5.5 successfully. What I did to make this work was the following:
munkipkg --import /path/to/VMwareFusion1153.pkg VMwareFusion1155
VMwareFusion1155
project directory which munkipkg
had set up and replaced the VMware Fusion.app
found at VMwareFusion1155/payload/Applications
with the VMware Fusion.app
for VMware Fusion 11.5.5.build_info.plist
found in the VMwareFusion1155
project directory to look like this:<?xml version="1.0" encoding="UTF-8"?>
<key>distribution_style</key>
<false/>
<key>identifier</key>
<string>com.vmware.fusion</string>
<key>install_location</key>
<string>/</string>
<key>name</key>
<string>VMware_Fusion_11.5.5.pkg</string>
<key>ownership</key>
<string>recommended</string>
<key>postinstall_action</key>
<string>none</string>
<key>preserve_xattr</key>
<true/>
<key>version</key>
<string>11.5.5</string>
I then built the VMware Fusion 11.5.5 package with the following command:
munkipkg /path/to/VMwareFusion1155
munkipkg
processed for a bit then delivered a package named VMware_Fusion_11.5.5.pkg
, which installed a fully working copy of VMware Fusion 11.5.5.
Posted on 05-31-2020 09:49 AM
Whitebox Packages fixed the issue in the past few versions, it also includes a command line tool.
http://s.sudre.free.fr/Software/Packages/about.html
Posted on 08-03-2020 07:29 AM
@rtrouton Thanks for posting this. I have been struggling with trying to get the 11.5.5 Fusion update packaged and deployed. Munkipkg worked great, I did have one question though, after install upon first launch (at least in macOS 10.15) there is an admin prompt for Fusion to configure a few things. Do you know a way to suppress this prompt for admin? We have users in our environment who do not have admin privileges. Thanks!
Posted on 08-03-2020 11:11 AM
FYI the AutoPkg recipe for creating a .pkg for VMware Fusion has been updated to work around this issue, and appears to be functional once again
