06:36 AM
07:26 AM
I have a computer that is in our Jamf instance but notice it has two configuration profiles installed that weren't created and deployed via Jamf. The configuration profiles installed are actually helpful so I'd like to upload it to Jamf so it can be deployed to other machines. Where can I find this mobileconfig file and or at the very least, extract / convert the profile to a PLIST file so it can be uploaded to Jamf?
Posted on 08-16-2019 07:26 AM
If you select the Profile in System Preferences you should be able to find the name of the file you are looking for. For example, I have one to set MS OneDrive, the details section tells me the file is "com.microsoft.OneDrive-mac" and then the settings that are configured. Locate that file and you can then extract or duplicate the settings you want to push.
