Posted on 06-23-2025 01:52 AM
I am currently migrating my distribution points from linux to windows. Up until now everything was smooth sailing, but now I have encountered a problem I do not know how to solve. When I try to install something via the new Distribution Point it first says the network connection has been interrupted and after the reconnect the package is no longer available. Any idea what this might be?
Here is the complete log output of the Policy I use:
[STEP 1 of 4] |
Executing Policy Spotify |
[STEP 2 of 4] |
Downloading Spotify-1.2.66.447.pkg... |
Downloading https://xxxx.xxxx.xx/jamfshare/Packages/Spotify-1.2.66.447.pkg... |
Error: Package was not successfully downloaded. -1012 |
The network connection was interrupted while downloading the package from https://xxxx.xxxx.xx/jamfshare/Packages/Spotify-1.2.66.447.pkg. Attempting to reconnect... |
Error: Spotify-1.2.66.447.pkg is not available on the HTTP server. |
[STEP 3 of 4] |
[STEP 4 of 4] Kind regards |
Posted on 06-24-2025 10:45 PM
Figured it out. Had to put the ADS/ before the user name in the HTTPS Settings
06-23-2025 05:57 AM - edited 06-23-2025 05:59 AM
@Andixon A "-1012" error typically indicates the SSL certificate isn't configured properly for HTTP server so check the HTTPS configuration for your new Distribution Point.
Posted on 06-23-2025 08:26 AM
@Andixon Can trust the certificate on a Mac and check. Else to isolate the certificate issue, switch over from HTTPS to HTTP.
Posted on 06-23-2025 08:47 AM
In this day and age one should never use HTTP for a Distribution Point, or SMB for that matter.
