Posted on 07-08-2024 04:45 AM
I would like to create a deployment for Maya 2025 based on the topic for 2024:
https://community.jamf.com/t5/jamf-pro/packaging-autodesk-maya-2024-with-redundant-license-servers/m...
I've found a .app installer in the Contents of the installer:
/tmp/maya2025/AdskIdentityManager/AdskIdentityManager-Installer.app
This app opens an installation wizard. How can I execute this (after the PKG installs) in silent mode?
Thank you.
Posted on 07-10-2024 01:19 AM
My solution is the following (only the installation part):
pkgpath="/tmp/InstallMaya2025.app"
installMaya() {
for PKG in $(find "$pkgpath" -name "*.pkg"); do
echo "Installing $PKG"
installer -pkg ${PKG} -target /
echo "Maya 2025 installed"
sleep 3
# Run the AdskIdentityManager-Installer.app in silent mode
"$pkgpath"/Contents/Helper/Packages/AdskIdentityManager/AdskIdentityManager-Installer.app/Contents/MacOS/installbuilder.sh --mode unattended
echo "Autodesk Identity Manager installed"
Posted on 07-08-2024 05:13 AM
In general to execute an installer silently you can use:
installer -pkg /tmp/maya2025/AdskIdentityManager/AdskIdentityManager-Installer.app -target /
Posted on 07-08-2024 11:20 AM
Unfortunately no luck with this command.
installer: Error - the package path specified was invalid: '/tmp/InstallMaya2025.app/Contents/Helper/Packages/AdskIdentityManager/AdskIdentityManager-Installer.app'.
Posted on 07-08-2024 11:50 AM
I believe the installer commands the XCLI version of the installer.app GUI and as such will only work with .pkg type files; if what you are attempting to install is a .app it could in theory, be opened with the CLI vi the 'open' command, but then you'd still have to deal with its GUI prompts.
Been awhile since I felt with Maya, but if the installer doesn't come packaged as a .pkg, run the installer, and then use composer to package Maya as a .pkg, then the JAMF native options or the above command would work.
Posted on 07-09-2024 02:42 AM
As I saw that, AdskIdentityManager-Installer.app writes files inside Maya.app, so maybe it's not the best approach to create a PKG from my installation.
Is it a possibility to run "Install Maya 2025.app" in silent mode via Jamf?
Posted on 07-09-2024 04:04 AM
I guess I've found a solution, but I'm gonna test via Jamf:
sudo /Volumes/Install\ Maya\ 2025/Install\ Maya\ 2025.app/Contents/Helper/Packages/AdskIdentityManager/AdskIdentityManager-Installer.app/Contents/MacOS/installbuilder.sh --mode unattended
Posted on 07-09-2024 09:55 AM
AdskIdentityManager doesn't install the full Maya software, only a component. I'm working to update the 2024 script for 2025 today.
Posted on 07-09-2024 10:43 AM
this has successfully tested for me:
#Application Info (For each AutoDesk app, change the app/year/pKey/package)
app="Maya"
year="2025"
pKey="#####"
#Location where the application file is going to sit (REMOVE THE SPACES IN NAME)
pkgpath="/private/tmp/InstallMaya2025.app"
#For Redundant Servers, have a space between them rather than a comma ex: networkServer="IPaddress1 IPaddress2 IPaddress3"
networkServer="##.##.##.###"
#Identify where the license file will be generated at
licPath="/Library/Application Support/Autodesk/AdskLicensingService/${pKey}_${year}.0.0.F"
licFile="licpath.lic"
#All packages that exist within the Package Contents, conduct install
runInstaller ()
#Creates and appends servers identified into 'new' license file, 'for each' server that exists, write to file
createLicenseFile ()
/bin/mkdir -p "${licPath}"
/usr/bin/touch "${licPath}/${licFile}"
for server in ${networkServer}; do
echo "Accounting for server $server"
/bin/echo "SERVER ${server} 000000000000" >> "${licPath}/${licFile}"
/bin/echo "USE_SERVER" >> "${licPath}/${licFile}"
/bin/echo "_NETWORK" >> "${licPath}/${licFile}"
#Append the license servers to the products installed, 'ls' is list servers based on @IP,@IP... distinction
LicenseHelper ()
### based off Onkstons's terrific work (I think they we're the first?) but simplified for 2023.
### see also, addl details at the end of script for alternative 'legit' licensing method.
/usr/bin/touch "${licPath}/licpath.lic"
/bin/echo "SERVER ${networkServer} 000000000000" > "${licPath}/licpath.lic"
/bin/echo "USE_SERVER" >> "${licPath}/licpath.lic"
/Library/Application\ Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper change --pk "${pKey}" --pv "${year}.0.0.F" --lm NETWORK --ls "${networkServer}"
#All files leveraged during installation will be cleaned from system package path and temporary files
cleanUp ()
/bin/rm -rf "{$pkgpath}"
#Run script (1st Pass)
echo "Starting 1st Pass"
runInstaller
createLicenseFile
LicenseHelper
#Run script (2nd Pass), the licensing portion doesn't always install/engage during first run
echo "Starting 2nd Pass"
runInstaller
LicenseHelper
#Cleanup Files
echo "Executing Cleanup"
cleanUp
### Verify license details - not required, but kind of nice to see.
/Library/Application\ Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper list
echo "Autodesk network licensing complete"
Posted on 08-20-2024 05:36 AM
why does the second run call the app installs again, if it's to double check licensing doesn't it just need to run the licensing function?
Posted on 08-20-2024 06:49 AM
I can confirm that Autodesk installations, even when done exactly per their instructions, are unreliable at best. I don't have mine set to repeat the installation, but I do have my policy set to ongoing with a smart group of "Maya installed" as an exclusion.
Then to keep it from installing every 30 minutes (on check-in), I simply set the install policy to run every night.
Posted on 08-20-2024 09:47 AM
@kacey3 @ianatkinson fwiw - most of the script above posted by @cgeorge is from my older work, but running the app installers a 2nd time in the script is not. My original script just re-ran the license function for good measure, as is noted in the comment. Additionally, this script still uses a mashup of old license file hackery techniques alongside official Autodesk workflows, which works but isn't ideal in my opinion.
Also fwiw- my new script/process down thread (dated 2024.07.19) uses official workflows for everything and has been flawless going out to ~200 lab computers for the past two years (including the ODIS curveball they hit us with this year). Feel free to use any or all of it - my point being that despite the PITA Autodesk can be, I can say for now at least a 100% success rate in deployments with network licensing is obtainable.
Posted on 08-21-2024 12:20 AM
Thanks I'm going to give your script a go today, I wrestled with this all yesterday afternoon and thought I'd got the licensing working ... pushed the policy and they've all failed :/
This was a lot simpler years ago when all you had was the one file telling it where the flex server was, this local licensing daemon that it seems to run now is what's causing the problems. Grrr!
08-21-2024 05:16 AM - edited 08-21-2024 05:17 AM
OK having spent a bit more time on this I think my issue was that the local licensing daemon wasn't always running. If it's not running then the file `
#!/usr/bin/env zsh
function start()
echo
echo "====================================================="
echo "| $1"
function uninstall()
# https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Clean-uninstall-of-Autodesk-programs-on-a-Mac.html
start "Removing old Autodesk Files"
rm -rf /Applications/Autodesk
rm -rf /Library/Logs/Autodesk
rm -rf /Library/Application\ Support/Autodesk
rm -rf /Library/LaunchDaemons/com.autodesk*
function runInstaller()
start "Installing $app"
function createLicenseFile()
if [[ ! -f "${licPath}/${licFile}" ]] ; then
start "Making license file"
function licenseProperly()
start "Licensing $app"
kills=0
# make sure daemon is running to accept registration
while [[ ! -f "/Library/Application Support/Autodesk/AdskLicensingService/AdskLicensingService.data" ]] ; do
echo "...kicking Autodesk licensing daemon"
killall -HUP AdskLicensingService
((kills++))
if [[ $kills -gt 5 ]] ; then
echo "FATAL: failed to get Autodesk Licensing daemon running"
exit 1
sleep 3
# register app
"/Library/Application Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper" register \
--pk "${pKey}" \
--pv "${year}.0.0.F" \
--cf "/Library/Application Support/Autodesk/Adlm/PIT/$year/${app}Config.pit" \
--lm NETWORK \
# check
if ! /Library/Application\ Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper list | grep -qi $pKey ; then
echo "ERROR, $app Licensing Failed"
echo "$app Licensing Complete"
# COMMON
networkServer="licensing.foo"
year="2025"
uninstall
createLicenseFile
# MAYA
pKey="657Q1"
app="Maya"
runInstaller
licenseProperly
# MUDBOX
pkgpath="/tmp/InstallMudbox2025.app"
pKey="498Q1"
app="Mudbox"
runInstaller
licenseProperly
# TIDY
chown -R root:wheel /Applications/Autodesk
chmod -R 755 /Applications/Autodesk
# /bin/rm -rf "{$pkgpath}"
Posted on 10-04-2024 02:03 AM
@cgeorge Are you able to share your 2024 Maya script having many problems with license side of things.
installMaya() {
sleep 3
Posted on 07-22-2024 11:42 AM
Hi All,
Here's my solution for installing 2025 (and 2024) versions Autodesk Maya, Mudbox, and AutoCAD with edu network licenses.
Steps are:
#!/bin/zsh
### Install Autodesk Apps and Licenses
### AutoCAD, Maya & MudBox (2025)
### 2025.07.19 -JonW
### Silently installs apps and licenses - no user interaction required
### Uses stock DMG's from Autodesk - no pkg hacking or repacking required!
### Works at loginwindow for multi-user lab/classroom deployment
### Tested on both 2024 & 2025 app versions (macOS 13 & 14) AutoCAD, Maya & MudBox
### A complete uninstall of previous versions is recommended but may not be necessary, ymmv
### Script could use some error checking, logging and fine tuning ... will get that on a slower day
### Ensure stock Autodesk install DMG's are set to CACHE (not INSTALL) via Jamf policy
### Update script variables in each of the 'app blocks' below
### - fyi check PIT (app config file) paths every year! Will need to perform a temporary manual installation to determine if they change or not.
### - fyi more info on license options: /Library/Application\ Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper register --help
### !!! Important !!!
### !!! 2025 Silent install patch info - aka ODIS update !!!
### https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/The-application-with-bundle-ID-com-autodesk-install-is-running-setugid-which-is-not-allowed-Exiting.html
### I had to tweak the ODIS patcher... It sort of defeats the purpose if the patcher itself doesn't work silently! C'mon Autodesk!
### (at least as of 2024.07.19) tweaks:
### - the /Volumes/Darwin/ path in the article is wrong! For me it's loading as: /Volumes/Macintosh\ HD\ 1/
### - this thing will throw Apple quarantine issues - resolving with xattr (i.e. just ignore the article instructions!)
### - the article makes no mention of the patch .sh script flag --mode unattended !!!
### I found it by digging around in the patch files! But hey, at least it's there right? It's always something isn't it!?
### Function
installApp ()
if [[ -e "${dmg}" ]]; then
### Mount dmg, install silently & unmount
echo "installing: ${dmg}"
hdiutil attach -nobrowse "${dmg}"
"${Setup}" --silent
hdiutil detach "${Volume}"
echo "cannot locate dmg for: ${dmg}"
echo "skipping install attempt"
### Function
applyLicense ()
if [[ -e "${ConfigFile}" ]]; then
### Apply License
### details: /Library/Application\ Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper register --help
/Library/Application\ Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper register --pk "${ProductKey}" --pv "${ProductVersionYear}${productVersion}" --cf ${ConfigFile} --lm NETWORK --ls "${networkLicenseServer}"
echo "license attempt failed, for product: ${ProductKey}"
echo ".pit config file could not be located"
### Function
silentInstallPatchODIS ()
### See notes above!!
### Tweaks as of 2025.07.19 - be aware Autodesk could change this at any time!
### This is the ODIS Update dmg
hdiutil attach -nobrowse /private/tmp/Darwin.dmg
### Let's move contents out of DMG to a tmp dir
mkdir -p /tmp/Autodesk_ODIS_Update_Contents
cp -R /Volumes/Macintosh\ HD\ 1/* /tmp/Autodesk_ODIS_Update_Contents
### Detach volume
hdiutil detach /Volumes/Macintosh\ HD\ 1
### fix quarantine issues - probably just need 2nd command, but let's go wild
xattr -rd com.apple.quarantine /tmp/Autodesk_ODIS_Update_Contents
xattr -rc /tmp/Autodesk_ODIS_Update_Contents
### run patch script - note, found ref to the --mode unattended flag buried in one of the supporting files, not in article?!?
/tmp/Autodesk_ODIS_Update_Contents/AdODIS-installer.app/Contents/MacOS/installbuilder.sh --mode unattended
### Begin script
### Move cached DMG's from Jamf staging area to /private/tmp/
mv /Library/Application\ Support/JAMF/Waiting\ Room/Autodesk* /private/tmp
mv /Library/Application\ Support/JAMF/Waiting\ Room/Darwin* /private/tmp
### Apply ODIS update - aka Silent install patch
### AutoCAD - install & license
networkLicenseServer="your.license.server.com"
ProductKey="777Q1" ### note, ProductKey may differ!
productVersion=".0.0.F" ### note, ProductVersion may differ!
ProductVersionYear="2025"
dmg=/private/tmp/Autodesk_AutoCAD_2025_macOS.dmg ### full path to install dmg in /tmp
Volume=/Volumes/Installer ### attached dmg volume
Setup=/Volumes/Installer/Install\ Autodesk\ AutoCAD\ 2025\ for\ Mac.app/Contents/Helper/Setup.app/Contents/MacOS/Setup ### full path of setup app
ConfigFile=/Library/Application\ Support/Autodesk/ADLM/.config/ProductInformation.pit ### full path of installed config file - used by license function
installApp
applyLicense
### Maya - install & license
ProductKey="657Q1" ### note, ProductKey may differ!
dmg=/private/tmp/Autodesk_Maya_2025_1_Update_macOS.dmg ### full path to install dmg in /tmp
Volume=/Volumes/Install\ Maya\ */ ### attached dmg volume
Setup=/Volumes/Install\ Maya\ 2025/Install\ Maya\ 2025.app/Contents/Helper/setup.app/Contents/MacOS/Setup ### full path of setup app
ConfigFile=/Library/Application\ Support/Autodesk/ADLM/PIT/2025/MayaConfig.pit ### full path of installed config file - used by license function
installApp
applyLicense
### Mudbox - install & license
ProductKey="498Q1" ### note, ProductKey may differ!
dmg=/private/tmp/Autodesk_Mudbox_2025_macOS.dmg ### full path to install dmg in /tmp
Volume=/Volumes/Install\ Mudbox\ */ ### attached dmg volume
Setup=/Volumes/Install\ Mudbox\ 2025/Install\ Mudbox\ 2025.app/Contents/Helper/setup.app/Contents/MacOS/Setup ### full path of setup app
ConfigFile=/Library/Application\ Support/Autodesk/ADLM/PIT/2025/MudboxConfig.pit ### full path of installed config file - used by license function
installApp
applyLicense
### Verify license details for all apps - optional, but nice to see in logs
echo "-------------------------"
echo "Autodesk install complete"
### Ensure dmg volumes are detached
### Temporary script step, added last minute. Still need to flesh this out
hdiutil detach /Volumes/Macintosh\ HD\ 1 > /dev/null 2>&1 ### This is the 'Darwin' ODIS Update dmg NOT the system volume
hdiutil detach /Volumes/Darwin* > /dev/null 2>&1
hdiutil detach /Volumes/Installer > /dev/null 2>&1
hdiutil detach /Volumes/Install\ Maya\ */ > /dev/null 2>&1
hdiutil detach /Volumes/Install\ Mudbox\ */ > /dev/null 2>&1
### Clean up installers - optional, /private/tmp should auto purge on reboot
### rm -rf /private/tmp/Autodesk*
### rm -rf /private/tmp/Darwin*
Posted on 07-22-2024 12:20 PM
I had just discovered the issue with the AdODIS patch and was trying to incorporate that fix into my own install script and stumbled upon this. Thank you so much for including the "--mode unattended" key in your script. This was the exact piece I was missing.
Posted on 08-08-2024 09:10 AM
Hey @jonw,
A few days ago I had managed to get this whole process working on my end, however now that I've updated the location of our license server I keep getting this error. I suspect that it has to do with the server update, but this same error happened when I changed it back to the original address. Any help would be appreciated!
Posted on 08-08-2024 09:38 AM
The error "com.autodesk.install is running setugid(), which is not allowed" is definitely related to the AdODIS patch, but I have no idea of how it plays into this situation. Did you uninstall everything before the re-install attempt? Or at least unload the Autodesk Daemons and remove anything relevant in /Library/Application Support/FLEXnet Publisher/Service (careful other apps may use FLEXnet)?
launchctl bootout system /Library/LaunchDaemons/com.autodesk.AdskLicensingService.plist
launchctl bootout system /Library/LaunchDaemons/com.autodesk.adskaccessservicehost.plist
### the two Autodesk related directories I currently (yours may differ)
rm -rf /Library/Application\ Support/FLEXnet\ Publisher/Service/11.16.6
rm -rf /Library/Application\ Support/FLEXnet\ Publisher/Service/11.18.3
Posted on 08-08-2024 09:40 AM
fwiw- you should be able to whip up a new script to just re-run the licensing bits with uninstalling apps.
Posted on 06-06-2025 10:45 AM
Does this script still work with Maya 2026? My understanding is that they no longer use a license server, but named user licenses like Adobe. Anyone get this running?
Posted on 06-06-2025 01:47 PM
@kwoodard You just threw me into a panic! 😅 However, I was just now able to download 2026 products and generate 2026 network license server keys valid until June 2026. The official statement is 'As of March 2026, new network and multi-seat licenses for Autodesk software will no longer be offered.' So it seems we can kick the can down the road for another year. I haven't had a chance to look into how their 'education institution subscription' option will function/deploy in a lab setting.
I won't have time to test for a few weeks, but I suspect my script from last year for 2024-2025 products (incorrectly dated 2025.07.19) above should work with the appropriate changes for 2026, assuming you're using network keys. If you do test before I do, I highly suggest a hand install of all apps FIRST to determine if there are any path/spelling changes besides the 'year' in all script variables.
I'll post a 2026 script & details in a few weeks when I have a chance to test.
Posted on 06-06-2025 02:01 PM
Our lead "guy" for Autodesk/Windows software wants us to go with the new edu install. I don't know why he wants to do it now, I assume its to work out any bugs before Fall semester...but it seems like a ton of work. We have to manually add all the students that will have access to the software.
How are you verifying paths to see if there are any changes. I guess literally just looking through Finder, but how do you know you didn't miss something? Why does AutoDesk need to make their installers so ridiculous?!
Another issue I have is that he isn't understanding that I need the optional installs as well, namely Substance... I gave him a link on how to create the Mac package and I get the "deer in the headlights" look when I ask about it. So very frustrating.
I look forward to seeing what you come up with. I have a test machine that I will try your script out on and see how it goes.
3 weeks ago
Any chance you have had success? I have been trying without luck. I'm starting to wonder if the guy that has the Autodesk admin that gets me the installers may have given me the wrong stuff...
I did get a Composer package that I am going to give a go just to see if its any faster. I doubt it will as its pretty big and has a ton of little files everywhere.
2 weeks ago - last edited 2 weeks ago
@kwoodard
Not sure if this is any use if still struggling with this, we currently use this for 2024. Looking to package 2026. Took many weeks last years as the installer is so poorly put togther.
#Copy installer app from .dmg to /tmp
#Modify values below as necessary (Usually: year and pKey)
#Set variables
year="2024"
pkgPath1="/private/tmp/InstallMaya2024.app/Contents/Helper/Packages/Maya/MayaUSD.pkg"
pkgPath2="/private/tmp/InstallMaya2024.app/Contents/Helper/Packages/Maya/Maya_AdLMconf2024.pkg"
pkgPath3="/private/tmp/InstallMaya2024.app/Contents/Helper/Packages/Licensing/adskflexnetserverIPV6.pkg"
pkgPath4="/private/tmp/InstallMaya2024.app/Contents/Helper/Packages/Licensing/AdskLicensing-14.4.0.11537-mac-installer.pkg"
pkgPath5="/private/tmp/InstallMaya2024.app/Contents/Helper/Packages/Maya/Maya_core2024.pkg"
pkgPath6="/private/tmp/InstallMaya2024.app/Contents/Helper/Packages/Maya/bifrost.pkg"
pkgPath7="/private/tmp/InstallMaya2024.app/Contents/Helper/Packages/Maya/MtoA.pkg"
pkgPath8="/private/tmp/InstallMaya2024.app//Contents/Helper/Packages/Maya/AdobeSubstance3DforMaya-2.4.0-2024-mac-universal.pkg"
mayapKey="657P1"
networkServer="your.license.server.goes.here"
mayalicPath="/Library/Application Support/Autodesk/AdskLicensingService/${mayapKey}_${year}.0.0.F"
mayalicFile="LICPATH.lic"
mayalgsFile="LGS.data"
#Mudbox
pkgPath9="/private/tmp/InstallMudbox2024.app/Contents/Helper/Packages/Licensing/AdskLicensing-14.4.0.11537-mac-installer.pkg"
pkgPath10="/private/tmp/InstallMudbox2024.app/Contents/Helper/Packages/Licensing/adskflexnetserverIPV6.pkg"
pkgPath11="/private/tmp/InstallMudbox2024.app/Contents/Helper/Packages/Mudbox/Mudbox_AdLMconf2024.pkg"
pkgPath12="/private/tmp/InstallMudbox2024.app/Contents/Helper/Packages/Mudbox/Mudbox_core2024.pkg"
mudboxpKey="498P1"
mudboxlicPath="/Library/Application Support/Autodesk/AdskLicensingService/${mudboxpKey}_${year}.0.0.F"
mudboxlicFile="LICPATH.lic"
mudboxlgsFile="LGS.data"
#Declare functions
# Check if licensing service is running
checkLicensingService ()
launchctl unload /Library/LaunchDaemons/com.autodesk.AdskLicensingService.plist
sleep 15
launchctl load -w /Library/LaunchDaemons/com.autodesk.AdskLicensingService.plist
sleep 15
#Give it time to start
if ! launchctl list | grep "com.autodesk.AdskLicensingService" > /dev/null;
then echo "license start failer"
# Call the function before running installers checkLicensingService
runInstaller ()
/usr/sbin/installer -verboseR -pkg "${pkgPath1}" -target /
/usr/sbin/installer -verboseR -pkg "${pkgPath2}" -target /
/usr/sbin/installer -verboseR -pkg "${pkgPath3}" -target /
/usr/sbin/installer -verboseR -pkg "${pkgPath4}" -target /
/usr/sbin/installer -verboseR -pkg "${pkgPath5}" -target /
/usr/sbin/installer -verboseR -pkg "${pkgPath6}" -target /
/usr/sbin/installer -verboseR -pkg "${pkgPath7}" -target /
/usr/sbin/installer -verboseR -pkg "${pkgPath8}" -target /
/usr/sbin/installer -verboseR -pkg "${pkgPath9}" -target / #Mudbox
/usr/sbin/installer -verboseR -pkg "${pkgPath10}" -target / #Mudbox
/usr/sbin/installer -verboseR -pkg "${pkgPath11}" -target / #Mudbox
/usr/sbin/installer -verboseR -pkg "${pkgPath12}" -target / #Mudbox
createMayaLicenseFiles ()
if [[ ! -e "${mayalicPath}" ]];
then
/bin/mkdir "${mayalicPath}"
/usr/bin/touch "${mayalicPath}/${mayalgsFile}"
/bin/chmod 777 "${mayalicPath}/${mayalgsFile}"
/usr/bin/touch "${mayalicPath}/${mayalicFile}"
/bin/chmod 777 "${mayalicPath}/${mayalicFile}"
/bin/echo "SERVER ${networkServer} 27000" > "${mayalicPath}/${mayalicFile}"
/bin/echo "USE_SERVER" >> "${mayalicPath}/${mayalicFile}"
/bin/echo "_NETWORK" >> "${mayalicPath}/${mayalgsFile}"
createMudboxLicenseFiles ()
if [[ ! -e "${mudboxlicPath}" ]];
then
/bin/mkdir "${mudboxlicPath}"
/usr/bin/touch "${mudboxlicPath}/${mudboxlgsFile}"
/bin/chmod 777 "${mudboxlicPath}/${mudboxlgsFile}"
/usr/bin/touch "${mudboxlicPath}/${mudboxlicFile}"
/bin/chmod 777 "${mudboxlicPath}/${mudboxlicFile}"
/bin/echo "SERVER ${networkServer} 27000" > "${mudboxlicPath}/${mudboxlicFile}"
/bin/echo "USE_SERVER" >> "${mudboxlicPath}/${mudboxlicFile}"
/bin/echo "_NETWORK" >> "${mudboxlicPath}/${mudboxlgsFile}"
MayalicenceHelper ()
/Library/Application\ Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper register --pk "657P1" --pv "2024.0.0.F" --cf /Library/Application\ Support/Autodesk/Adlm/PIT/2024/MayaConfig.pit --lm NETWORK --ls "your.license.server.goes.here"
MudboxlicenceHelper ()
/Library/Application\ Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper register --pk "498P1" --pv "2024.0.0.F" --cf /Library/Application\ Support/Autodesk/Adlm/Library/Application\ Support/Autodesk/Adlm/PIT/2024/MudboxConfig.pit --lm NETWORK --ls "your.license.server.goes.here"
cleanUp ()
/bin/rm -rf "${pkgPath}"
/bin/rm -rf "${tmpfile}"
Checklicense ()
{ if /Library/Application\ Support/Autodesk/AdskLicensing/Current/helper/AdskLicensingInstHelper list
then
#Run script
runInstaller
MayalicenceHelper
MudboxlicenceHelper
Checklicense
cleanUp
