Posted on 07-18-2024 01:31 PM
An org’s network requires non-personal devices (think digital signage, inventory scanners, etc...) to be bound to a set network using MAC address. That then requires “Private Wi-Fi Address” to be disabled on all the iOS devices otherwise the device MAC does not match up to the registered MAC.
For these type devices, I have a config set to disable “Private Wi-Fi Address” but that only comes through AFTER the device is enrolled (and gets internet access of course). With a random MAC, the device cannot do the initial out of box activation and eventually times out. I can get around all of that with a USB ethernet dongle, which allows the device to get online, enroll, get wifi config settings etc... but that is time consuming.
Does anyone know of a way to disable the private wi-fi address setting when you first connect a device to wifi out of the box?
I have tried backing out on the setup screen and holding the wifi name in question to try and bring up options, but so far no luck. I know I have seen some type of "Advanced Options" related to wifi at setup, but I cannot get it to manually appear and am hoping there is some direct access for it.
07-19-2024 05:49 AM - edited 07-19-2024 06:00 AM
Isn't this macOS 15 Beta stuff?
As far as adjusting macOS Configurations, there is no way to do this pre-enrollment. Your best bet is to setup an Enrollment only Wi-Fi network that does not have the same obtuse security requirements or use ethernet as you suggested.
Edit:
I forgot to mention, this is the kind of thing you want to submit Feedback for.
https://feedback.apple.com/ (or better yet use the feedback app with your managed AppleID signed in)
4 weeks ago
I know this is an old topic, but there actually is a way, but it requires you to make the device kinda mad. I just went through this helping another college at the school I work at. Pretty much keep hitting every other wifi option except the one you want to use, and eventually it'll get mad and give the options to access "settings," and a little (i) will pop up next to all the available wifi connections. Hit that on the wifi you want to use, then turn off private/rotating wifi.
