On-premises DP Usage
ashwina1995
Hi Team,
How to check JAMF on-premises DP usage?
5 REPLIES 5
jamf-42
launch jamf admin. this will mount the share. you can then see usage.
or check on the server / system that is providing the share
ashwina1995
Can you please provide those steps
@ashwina1995 Are you asking about the storage usage, or the amount of network traffic from your on-prem DP? Jamf Admin should show you the former, but there is no information in Jamf Pro on the latter.
ashwina1995
I want to know those DP’s are still used for production or not. Does any end user machine utilise those DP or not.
@ashwina1995 The only way I know of to determine that would be to look at policy logs which install something to see what DP they download the install package from.
If your Principal DP is a Cloud DP, and you don't have any Network Segments defined for your internal network that specify a Default Distribution Point which is one of your internal DPs, you could try just disabling your internal DPs.
