a month ago
Hi Guys,
We are trying to implement Device Trust with OKTA and JAMF. While setting up OKTA verify app in mac, we are unable to silently enrol the user account into OKTA Verify app without user intervention. The OKTA Verify app configuration documentation by OKTA doesn't have any info.
Is it possible to register OKTA verify app into user account automatically without needing user to do manually.
Thank you
a month ago
Okta is an identity management tool, I personally dont see how you would validate user identity without the user being interactively involved. It may be possible if you used PSSO with Okta, as macOS would have a token it could pass from the login screen that they already interactively created. However, this is all Okta and I recommend reaching out to Okta on this one.
a month ago
a month ago
Hi @Yam_Moktan I don't think its possible. User need to authenticate for configuring the Okta Verify. You can reach out in Okta channel in Mac Admins slack.
Thanks.
4 weeks ago
Hi @AJPinto @karthikeyan_mac
Thank you for your reply, yeah looks like its not possible which was my thought as well. But the project team was almost sure we can do this without user interaction.
