New smart groups of static groups showing 0 devices
MoAlJuboori
I'm trying to create a smart group of our labs (static groups) but its not working, it can only take one at a time.
I've tried re-creating the static groups, still no luck, it will only show one (7 devices or 43 device but never 50).
i did add the site location and the "(" ")'' & "and".
Is anyone else experiencing this? our current instance is 11.10.2
johnalimin
Perhaps try "or" instead of "and"
Cheers,
johnalimin
Cheers,
It's confusing as I'm trying to cover all of them, but "or" does get the correct count of the groups anyway :D Thanks.
@MoAlJuboori When you use the "AND" conditional with multiple Static Groups a Mac must be a member of ALL of those Static groups connected by AND to be included in your Smart Group. The "OR" conditional will include a Mac that appears in ANY of the Static Groups connected by OR.
