06:47 AM
08:59 AM
I just spun up a brand new instance of the NetSUS 4.1.0 appliance (.ova file) and set the Software Update Server's Daily Sync Time to 3AM. However, the web GUI is showing that my last sync ran over a week ago. Does anyone know how the daily sync is triggered (so that I can investigate if the GUI is actually setting it up correctly) and where it might log to so that I can check for errors? Manual sync works fine.
Thanks,
Eric
Posted on 07-28-2016 03:23 PM
I'm having a similar issue where it's not synchronizing all of the updates from Apple.
NetSUS 4.1.0 discussion
Posted on 07-28-2016 04:01 PM
@itupshot Is that even after running a manual sync?
FWIW I found that the daily sync is configured in cron and the crontab file looks correct. Checking the cron logs I don't see it attempting to run, so I'm at a bit of a loss where to go from here.
Posted on 08-05-2016 11:55 AM
@etippett Same thing. I don't know if it's doing anything. I checked again today after doing a manual sync, and it's still missing a lot of updates.
Posted on 08-05-2016 12:05 PM
Strange. I just checked mine and even though the Last Sync date says July 20, it has updates as recent as August 3rd. I know I've not initiated a manual sync in at least a week, so apparently the scheduled sync is running but not updating the webpage.
Posted on 04-17-2017 12:50 PM
Has anyone found a fix for this?
