Need to disable Hand-Driven Reactions on MacOS
bharathmudiraj
Need to disable Hand-Driven Reactions on MacOS (Thumbs up and 2 fingers on a meeting on MacOS can trigger fireworks, balloons, etc.)
We are managing MAC devices from Mosyle tool (Alternate of JAMF)
I want to disable this reaction feature for all the devices centrally on all the apps as this is Mac OS feature want to disable this feature on Mac centrally using a script.
I know we can disable it by clicking on Green symbol and click on reactions when an app id open, but we want to disable this from Mosyle portal the reason we need a Script.
Can someone help me with this.
macm1
Here is a great repo that will allow you to disable the reactions:
https://github.com/poundbangbash/community-video-reactions-management
macm1
Quick question on that repo...if I set this up is a configuration profile, do I use "group.com.apple.secure-control-center-preferences.av" as the domain?
bharathmudiraj
Thanks a ton @macm1 it worked Kudos to you.
