08:21 AM
08:29 AM
Posted on 11-05-2018 09:17 AM
Check out the MobileConfigs in these repos.
You'll want this one - https://github.com/jamf/JamfPrivacyPreferencePolicyControlProfiles
and here are some more white lists - most notably the Terminal & Shell/Python MobileConfig Whitelists.
https://github.com/carlashley/tccprofile/tree/master/generated_profiles
Posted on 11-06-2018 07:01 AM
I've got the jamf one and I had my own versions of carlashley's. I swapped mine for carl's but still have same results.
Posted on 11-06-2018 10:51 AM
very strange, especially since you've deployed the mobile config directly from jamf to the machines to allow jamf to run scripts.
I would escalate this to a Jamf Support Case so they can dig deeper!
Wish I could help more, best of luck!
