09:03 AM
06:01 AM
Just a quick question, but since our JumpStart was quite a few months ago, I have forgotten where/if you can make changes to it. Because when imaging, the machine is not enrolled into the JSS and the time isn't set, etc etc.
Thanks,
Posted on 11-17-2016 01:23 PM
Ours is just a script in the JSS set to run on reboot and added to the configuration... It doesn't need to be enrolled to run it as it is copied down to the machine during imaging.
Mind you I made it that way so it may not be done in the same way by everyone.
