08:08 AM
07:52 AM
Has anyone had any luck with getting the new Malwarebytes for Mac 3 menu bar item hidden from a policy or script? Been digging through the Application Support and Preferences for by the OS and User, and can't seem to find anything that changes if you check or uncheck the "Hide Application Icon" in the Malwarebytes settings. Thank you for any help you can provide!
Posted on 09-26-2017 07:00 PM
I asked Thomas Reed of MalwareBytes about this on MacAdmins Slack, and his response was "I don't think there's a way to do that currently."
You may want to contact their support and submit this as a feature request.
Posted on 09-26-2017 08:16 AM
Use Composer in the "Monitor File System Changes" mode to capture what files/plists are being written to when you make the change in the MalwareBytes UI. It has to be writing the change to something. Composer may be able to reveal it so you can then see if scripting the same change would be possible.
Posted on 10-12-2017 09:37 AM
As nice as this would be, I'm more frustrated by the app version number being inaccurate. Installed 3.0.3 and the app version in Get Info and the info.plist is still listed as 3.0.3. Sigh. :-p
Posted on 10-12-2017 02:37 PM
@cwaldrip I think you have a typo there. It looks like you're complaining about the Get Info section showing the correct version number for the program.
Posted on 10-13-2017 08:22 AM
@McAwesome You're correct. Get Info and info.plist are showing 3.0, when it actually should be 3.0.3. Makes tracking installed versions impossible for now. Luckily it's not like 3.0 vs. 4.0. ;-)
Posted on 03-24-2021 06:00 AM
Malwarebytes uninstall script anything is available?
