04:55 AM
05:40 AM
I've upgraded my JSS on Windows to 10.9 and am trying to setup automatic database backups using the new Jamf Pro Server Tools. But when I do a test connection to the database I'm getting the following error:
Error 1045: Access denied for user 'jamfsoftware'@'localhost' (using password: NO).
I have a password entered in the Database Password field and I know it works as I've just tested it using mysql.exe in the CLI.
Any ideas?
Posted on 01-02-2019 02:51 PM
I am encountering this same issue. Did you find a solution, @sedwards ?
Posted on 01-02-2019 03:11 PM
Have you tried including the entire path to the tools & running Command Prompt as Administrator?
Ex:
C:Program FilesJSSinjamf-pro config list or cd C:Program FilesJSSin jamf-pro config list
https://www.jamf.com/jamf-nation/articles/531/converting-the-mysql-database-storage-engine-from-myisam-to-innodb-using-the-jamf-pro-server-tools-command-line-interface#responseChild2442
*Article isn't directly related but helped me with the initial setup.
