Jamf Pro - How to prevent the removal of Device Management on IPads by end user.
jamesurencpps
Does anyone know if it is still possible to prevent the removal of management profiles on Jamf Pro for iPads?
I believe there used to be a iPad restriction to do this. I can't seem to find it now.
Any help would be most appreciated.
Rocketman_Zac
The place is in a Mobile Device Prestage Enrollment. It's a checkbox on the General tab that says "Prevent unenrollment", with descriptor, "Disallow the user from removing the MDM profile".
This setting applies to the MDM profile when the iPad goes through Setup Assistant. To replace removable profiles with non-removable ones, the iPads must be re-activated through the Prestage Enrollment configured like above.
Looking for a Jamf Managed Service Provider? Look no further than Rocketman
Are you guys using DEP?
Rocketman_Zac
I have checked this option but still user are able to remove DMD Profile from an IOS device.
@AJPinto if you can help here, i will be greatful.
I have checked this option but still user are able to remove DMD Profile from an IOS device with passcode.
