2 weeks ago
I have just enabled the Compliance Benchmarks available from within JAMF Pro, however: -
Can there be an option to exclude versions of macOS?
So we are having our minimum OS as Sequoia, therefore do not need the Sonoma or Ventura policies at all; or can I just delete the ones I do not need?
2 weeks ago
Before setting up the Compliance Benchmark, setup your Smart Group however you would want, which in your case would be based on the version of macOS you want to include, which should exclude the OS verison you don't want. Then when you setup your Compliance Benchmark, scope it to the Smart Group you created.
2 weeks ago
Whilst this is an idea I had; it doesn't really work as the Benchmark 'Wizard' creates it's own Policies and Config Profiles.
The issue is it creates for Ventura, Sonoma and Sequoia, whereas the Ventura & Sonoma ones are not required,
I'm think as I'm not likely to amend the benchmark again, can I just delete the Ventura & Sonoma ones?
2 weeks ago
The wizard makes policies and config profiles but you can still descope them if needed.
