06:12 AM
06:32 AM
I have a collègue who is having issue connecting to SMB/domain.inc/dfsroot works fine locally but when connecting via the VPN (IPsec) always gets the error "connexion failled to serveur domain.inc... it is possible that the server does not exist or is not available at this time ....".
This used to work before upgrading to 10.13.1
Other things that I have tried
Any suggestion on next things to look for ?
Thx
Posted on 11-27-2017 10:53 AM
Hi there,
I had similar issues with High Sierra, but we are connecting to a Linux NAS. The SMB protocol is not working and we get the same error message as you described above; we found a workaround for now using AFP protocol instead of SMB, but I doubt this would work for Microsoft Windows Server.
Posted on 02-02-2018 01:03 AM
Hello,
Upgraded a test MacPro to High Sierra 10.13.3 and am experiencing the same SMB problems everyone was having with Finder hangs when moving or changing a folder name but, only with DFS, over SMB. Once it hangs only a restart can get the system back. Tried using cifs: but that does same thing. Looking for a fix for accessing a DFS namespace share on Windows Server.
Posted on 02-12-2018 02:41 PM
High Sierra 10.13.3 is supposed to fix this issue but I have one user who is now unable to reliably connect to the server.
the fix in 10.13.2 is to edit (or create) the /etc/nsmb.conf file to:
[default]
protocol_vers_map=2
(found this tip elsewhere on the forums here)
This worked until the user updated to 10.13.3 but now we're getting 'access to this has been denied for your account, please see your administrator' I know the account isn't locked out, as the computer's joined to the domain and the person is using their domain credentials to log on; the affected share is her network home directory. Other shares intermittently do the same thing, but sometimes they just work as expected.
I"m going through a packet capture file right now to see if anything jumps out.
