09:56 AM
05:30 AM
Hi All.
So in order to have AD Users listed in FileVault2 they have to be enabled. I am using the JAMF script to do that already, however, I like to create an ongoing pop-up message informing NONE FileVault 2 Enabled Users to run the script to enable their account for FileVault2.
I figured a Smart Group is the way to go. But I cant figured the right combination to have this happen. Any ideas are welcome. Thank you.
Posted on 08-19-2016 11:11 AM
Not sure if the built in criteria "FileVault 2 User" could do it, failing that you could build a script populated extension attribute that could give you some more options. Something like:
numberOfUsers=$(fdesetup list | grep -c "[A-z 0-9]")
echo "<result>$numberOfUsers</result>
I haven't tried this on a FV enabled Mac with no users enabled though so not sure if zero is possible. I guess if you have an admin user already enabled, you're just looking for ones that only return a 1.
