06:57 AM
02:39 AM
Is there a way to completely enroll a device in JAMF, Using apple Configurator? I'm switching some of my devices over to shared devices, and am wondering if i can automat the entire process in configurator so there is no setup on the device.
Posted on 01-25-2018 07:08 AM
If you're using DEP, you can have Configurator add the device to DEP and that will add it into JAMF
Posted on 01-25-2018 09:42 AM
yes but can it do the config also. assign to user ect....
Posted on 01-26-2018 11:41 AM
Yes; The short of it is by using the one place both Apple Configurator and Jamf pull from -> DEP.
In Jamf; Create a DEP Supervision Identity that can be trusted by devices enrolled via Apple Configurator (Devices>Settings>Global Management>Device Enrollment Program)
Now maybe an expert can pick us up from there - i.e creating and importing server token files for use with Apple Configurator.
