Is there a way jamf can see who is using a specific tool, such as Apple Intelligence?
eqm
Hi all,
We are trying to determine if we can use Jamf to audit which users are actively using Apple Intelligence.
Our hunch is that Apple doesn't log gen AI actions but I was wondering if anyone here might have some specific advice that could help.
Thanks in advance!
5 REPLIES 5
There is no way to monitor this that I am aware of in the MDM or Security framework. There is an off chance there are console logs that you may be able to pick up with a log filter, but it’s a long shot at best.
Honestly, I am kind of curious myself now that you ask.
PMullins1
You could try the "scream test" - disable it and see who screams.
daniel_behan
@daniel_behan This is exactly what I needed. Thank you!
Thanks! We are going to give this a try.
