11:57 AM
06:36 AM
Hi there, I'm trying to figure out the "sudo jamf install -package" command and I'm having trouble figuring out the syntax. This command can be used for installing packages on the jamf server, not only on the local machine, correct?
Posted on 11-05-2019 12:23 PM
@evangardner No, it's for installing packages on the local machine (i.e the one you're running the command on)
Posted on 11-05-2019 01:56 PM
If you run:
jamf help install
these are the options for that command. What is the goal you are trying to accomplish? Policies work well for installing .pkgs
jamf help install
Usage: jamf install -package <filename> -path <path to file> -target <volume>
[-fut] [-feu] [-showProgress]
-package The filename of the package that will be installed.
-path The path to the package. This does not include the name of the package.
-target The drive that the package will be installed to.
-fut The Fill User Templates option takes any user data
and populates the files to the user templates so any new
user created on the system will have these files.
-feu Fill Existing Users option takes any user data and
populates the files to every user on the computer that has a
home directory.
-showProgress Displays the progress of the HTTP download and the progress of the installation process.
