02:03 PM
06:38 AM
Hi all,
I've seen various threads on this, some dating back to years ago, and I was hoping to get some concrete suggestions on the most efficient way to go about this.
We're wanting to deploy only the VPN, Umbrella, and AMP portions of AnyConnect, along with their respective config files from our organization. I've seen seen mention of using the Packages app, as well as Pacifist, but going that route leads to the com.apple.installer issue. I've tried a myriad of different things, but I can't seem to get it setup without issue.
Any insight is greatly appreciated!
Posted on 01-16-2019 03:09 PM
@landon_Starr using a Choices.xml
file is your best bet. You can check out this blog post:
Using installer choices.xml to modify AnyConnect and McAfee deployments
That's what we do. I package the AnyConnect installer direct from Cisco, along with the Choices.xml file and a postinstall script. I drop the PKG file and the XML into /tmp
and then the postinstall script installs them:
anyChoice="All-AnyConnectChoices.xml"
anyInstall="AnyConnect_4.7.00136.pkg"
/usr/sbin/installer -applyChoiceChangesXML /tmp/${anyChoice} -pkg /tmp/${anyInstall} -target /
Could take it a step further and instead of a postinstall use a script in a policy set to After with Parameter 4 and 5 set to the name of the package and the XML file. That would make it more universal (the script that is) so that it could be used for other apps like Office or anything else you only want pieces from.
Hope that makes sense.
Posted on 01-17-2019 08:21 AM
For some reason, the idea of distributing a package that includes features I will never use bothers me.
I used to crack open the flat metapackage with pkgutil
, remove the superfluous packages, and then modify the Distribution
file to only point to the remaining packages, but I got tired of doing that every time so I wrote a python script that breaks it down and does all the work for me.
Unfortunately it relies on some of my custom libraries so I can't just copy/paste it here for you to use. I can maybe modify it to include the missing functions.
Posted on 01-17-2019 09:40 AM
Hey @stevewood ,
Thanks for your help! That's the first time I've come across the page you shared, and it definitely helpful.
Though it still looks like I'm missing something. I threw the AnyConnect.pkg file, along with the XML file under /tmp. I modified the XML so that it should only install the VPN and Umbrella portions of the application:
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <array> <dict> <key>attributeSetting</key> <integer>1</integer> <key>choiceAttribute</key> <string>selected</string> <key>choiceIdentifier</key> <string>choice_vpn</string> </dict> <dict> <key>attributeSetting</key> <integer>0</integer> <key>choiceAttribute</key> <string>selected</string> <key>choiceIdentifier</key> <string>choice_websecurity</string> </dict> <dict> <key>attributeSetting</key> <integer>0</integer> <key>choiceAttribute</key> <string>selected</string> <key>choiceIdentifier</key> <string>choice_fireamp</string> </dict> <dict> <key>attributeSetting</key> <integer>0</integer> <key>choiceAttribute</key> <string>selected</string> <key>choiceIdentifier</key> <string>choice_dart</string> </dict> <dict> <key>attributeSetting</key> <integer>0</integer> <key>choiceAttribute</key> <string>selected</string> <key>choiceIdentifier</key> <string>choice_posture</string> </dict> <dict> <key>attributeSetting</key> <integer>0</integer> <key>choiceAttribute</key> <string>selected</string> <key>choiceIdentifier</key> <string>choice_iseposture</string> </dict> <dict> <key>attributeSetting</key> <integer>0</integer> <key>choiceAttribute</key> <string>selected</string> <key>choiceIdentifier</key> <string>choice_nvm</string> </dict> <dict> <key>attributeSetting</key> <integer>1</integer> <key>choiceAttribute</key> <string>selected</string> <key>choiceIdentifier</key> <string>choice_umbrella</string> </dict> </array> </plist>
And then copied over the little post install: (changing the variables, of course)
#!/bin/bash anyChoice="AnyConnectChoices.xml" anyInstall="AnyConnect.pkg" /usr/sbin/installer -applyChoiceChangesXML /tmp/${anyChoice} -pkg /tmp/${anyInstall} -target / exit 0
Upon testing the install, every component was installed. Am I a big dummy and miss something super simple?
Posted on 04-05-2019 10:14 AM
I got the install to work by creating the choice.xml
What i do get now is the user is prompted to open the security Pref Pane and allow the app extension. Anyone know a way to automate that process so that it is a completely silent install?
Posted on 04-08-2019 03:53 AM
I presume you are talking about the kernel extension warning. you need to create a profile for it and ensure it deploys to the devices. This will be useful . Like this example for McAfee.
Posted on 11-05-2019 10:45 AM
Hi all, I am currently seeking how to customize the Cisco installer for Mac also so I can auto install it upon enrollment on my MacBook pros, that being said Its new to me and im struggling to understand some of it. Also a road block im hitting is, understanding how to have the user Cert from the Entradus- CA either pulled down or on the Mac and not stored in login keychain. Basically currently Pre MDM, my predecessors manually installed the user cert VPN wants to verify, I have yet to understand how to pull this cert down etc with JAMF.
Posted on 01-21-2020 12:54 PM
Hey all- I hate to resurrect a year-old thread but I've been following the advice here and I am so close to packing the VPN-only module for my Self Service. If I run the following command locally AnyConnect installs exactly how I want it to:
sudo installer -applyChoiceChangesXML /Users/me/Desktop/choices.xml -pkg /Users/me/Desktop/AnyConnect.pkg -target /
But if I package everything and run the Self Service policy I get the following error when trying to download the XML:
Installing choices.xml...
Installation failed. The installer reported: installer: Error - the package path specified was invalid: '/Library/Application Support/JAMF/Downloads/choices.xml.pkg'.
Any idea what I'm doing wrong here? The AnyConnect.pkg installs fine, as does my XML which adds custom addresses to the VPN moduel... but not the choices.xml.
Posted on 01-21-2020 11:49 PM
O, bearers of truth!
O, wreckers of dreams!
Come forth and exclaim
that all our great schemes
and policies drafted
shall all be for naught;
that packages crafted
shall wither and rot
when dread Catalina
enforces new rules
and notarization
makes all of us fools.
Posted on 01-22-2020 01:08 PM
Does this mean... none of the above actually does the trick on 10.15?
Posted on 01-23-2020 10:00 AM
I am packaging AnyConnect 4.8 for Catalina. This is the first version that will actually work correctly with 10.15. I am not doing any thing different than with previous versions.
Expand the anyconnect.pkg so you can modify the dist file
Pkgutil --expand AnyConnect.pkg ~/Documents/AnyConnectVPN
then I opened the Distribution file inside of the expanded package
This is what I wanted to install
<choices-outline>
<line choice="choice_vpn"/>
<line choice="choice_dart"/>
<line choice="choice_posture"/>
</choices-outline>
Save the list file
Flatten the pkg and then you can install.
pkgutil --flatten ~/Documents/AnyConnectVPN ~/Desktop/AnyConnect.pkg
This works for us.
Posted on 03-04-2022 04:01 PM
I can confirm that this works for 4.9 on Monterey. Just need to get the extension to auto approve so the user doesnt have to.
Posted on 01-23-2020 12:36 PM
Dude. That is the answer. That is ALL we have to do. I don't understand why the XML with the post-install script is necessary in this case. ??? I removed all the modules I do not want installed (basically everything except VPN) and re-flattened the PKG. Uploaded, updated my policy, and bam. Thank you.
Posted on 01-23-2020 01:11 PM
I am testing 4.8, and solution which @MikeF mentions - it works for me as well
Posted on 01-23-2020 01:44 PM
I just repackaged 4.8.02042. All went fine the way I described.
Posted on 01-24-2020 12:48 PM
This worked wonderfully! I have another question about this though. Is it possible to supply the server address, so that it automatically populates in the client, in the Distribution list or would that be under a .plist?
Posted on 01-24-2020 01:29 PM
I know there is a way with the profiles on the install to do it but we are doing it a little differently. We end up with a xml file in this folder
/opt/cisco/anyconnect/profile/????.xml
After we set up a machine we package this file in composer and have it installed along with the AnyConnect package. We install AnyConnect and then drop in the profile xml file and the next time that anyconnect opens it reads that file and has all the server addresses. We have multiple access points worldwide and this works for that.
All you should have to do is make that first connection and then the xml file should be created for you. Just use that for the rest of the systems.
Posted on 04-17-2020 09:19 PM
sorry, it looks like I had to initially cd to the correct directory (thought I tried it at first) and then was able to fix my error. Great tip none the less, thank you!
~~just came across @MikeF's method, however no matter what I try terminal outputs the error:
Could not open package for expansion: AnyConnect.pkg
I have it in the directory ~/Desktop/anyconnect
pkgutil --expand AnyConnect.pkg ~/Desktop/anyconnect
any suggestions? this happens on v4.7.x and 4.8.x of anyconnect on 10.15.4~~
Posted on 04-17-2020 10:13 PM
@walt not sure if the syntax is causing the error, but don't you need to state package name of source and target?
pkgutil --expand ~/Desktop/anyconnect/AnyConnect.pkg ~/Desktop/anyconnect/AnyConnect-expanded.pkg
Found out on Friday that 4.7 has a broken KEXT Team Identifier, fixed in 4.8. To see for yourself, run:
codesign -dr - /Applications/Cisco/Cisco AnyConnect Secure Mobility Client.app
If you have 4.7 installed, you'll get a long string; if you have 4.8 installed you'll get the Team Identifier.
Posted on 04-22-2020 12:04 AM
Hi JamfNation,
Does Cisco anyconnect 4.8 Fix the Kernel extension pop ups in catalina?
or need to create a separate PPPC/Config for that
Posted on 04-22-2020 09:44 AM
There is nothing for Cisco to fix. You need to deliver proper PPPC and Approved Kernel Extensions for AnyConnect and any other software that might use those controlled frameworks.
Posted on 11-20-2020 05:29 AM
I try to deploy anyconnect-macos-4.9.04043. I do like below (copied from this post earlier) - but cisco is not installed after the package has run. Anyone had luck with this ?
*Expand the anyconnect.pkg so you can modify the dist file
<choices-outline> <line choice="choice_vpn"/>
</choices-outline>
Save the list file
pkgutil --flatten ~/Documents/AnyConnectVPN ~/Desktop/AnyConnect.pkg*
Posted on 11-20-2020 08:45 AM
@jameson It works for me. I repackaged AnyConnect ver. 4.9.04043 this way with only VPN and DART modules
Posted on 11-21-2020 02:04 PM
can you try and paste what you have in distrubtion file ? - something I must be missing, as this should be stright out of the box working. But the package install for me, but cisco is not installed - really strange behavior. So somehow seems to be an empty package I install
Posted on 11-22-2020 10:33 AM
This is what I have for 4.9.03047
I am showing the only part of the distribution file i changed
choices-outline> <line choice="choice_vpn"/> <line choice="choice_websecurity"/> <line choice="choice_dart"/> <line choice="choice_posture"/> <line choice="choice_umbrella"/> </choices-outline>
These are the option i install if you do not want some of it just delete the lines you don't want.
I did not modify any thing else.
Just make sure to save the file and then flatten the package.
I will be making this up for the new release but not until after Thanksgiving.
Posted on 11-22-2020 11:49 PM
OK - found the magic
So new week new try. Did reset my test machine, did redo all the pkgutil - created a new policy - and BAM - cisco showed up
Really strange for me as I did the exact last week. So removed cisco in application and imported the package in the originally policy. And then it was gone again! - it was installing without any error, but cisco folder did not show up in applications
I removed all settings in the originally policy and the package did not show up - and even the test policy did also not work anymore.
So my guess was that something must be stuck from the first install that worked. So found the magic command here
sudo pkgutil --forget com.cisco.pkg.anyconnect.vpn
This must be run if want to re-do installation. That was close to 1 day I spent on this silly issue, so nothing was wrong with my package, just that command must be run
Posted on 02-24-2021 09:34 AM
As information (and maybe as reminder for me when I face the same problem again)
I first did as described above:
mounted the anyconnect-macos-4.9.06037-predeploy-k9.dmg and copied the AnyConnect.pkg to my Desktop
Then I expanded it with the command:
pkgutil --expand AnyConnect.pkg pkg_dev/expand/AnyConnect
Now I deleted all pkgs inside I don't need (we only need the VPN installer) and edited the Distribution File by deleting or commenting out the not needed installation pkgs
After that I did:
pkgutil --flatten pkg_dev/expand/AnyConnect AnyConnect.pkg
I was able to install this pkg by double clicking it but JAMF was not able to install it for me
Error: pkg uses a deprecated pre-10.2 format
Also did not delete the not needed pkgs, same error
What was then working was just flatten the vpn_module.pkg
pkgutil --flatten pkg_dev/expand/AnyConnect/vpn_module.pkg Cisco AnyConnect 4.9.06037_VPNonly.pkg
Now the installation with JAMF was working.
Maybe this might be useful for someone else ;)
BR
Daniel
Posted on 10-01-2021 03:13 PM
Hello dptratl how do you add the profile and choice into the package?
Posted on 10-04-2021 06:22 AM
I currently have the latest version of anyconnect packages this way.
I have found that changing the name of the package to any thing other that AnyConnect.pkg that is created by the process and it will fail to install. Create the package and after that renaming will work.
I would not delete any thing from the package. I don't and it works. only change you make is editing the distribution file.
Also there have been questions on the profiles in this PKG. I do not include these but rather place the correct xml file in the /opt directory location for profiles. You just package this with composer from a working system. It will install the profile. After that our concentrators will send any update's.
Posted on 10-04-2021 07:13 AM
Hi @EddyLara,
We provide the profile and connection nodes with a seperate pkg which installs the edited AnyConnectProfile.xml to the path /opt/cisco/anyconnect/profile/
I hope that helps.
BR
Daniel
Posted on 01-26-2023 12:35 PM
For the record, I tried using pkgutil to remove the VPN as we do not need it.. But it breaks the installation.
I am able to remove everything else, just not VPN.
Anyone else having this issue I am open to hearing any work arounds.
Posted on 01-26-2023 02:10 PM
I was repacking version 4.10.06 today with only VPN and DART modules, everything was working fine, as usual. Tested, installed recombined package.
Posted on 03-06-2024 12:48 PM
can you share how you repackage? I am working on the same with the newer Cisco Secure Client 5.0 and tried the following:
pkgutil --expand Path/Cisco\ Secure\ Client.pkg path/Cisco\ Secure\ Client
pkgutil --flatten path/Cisco\ Secure\ Client Path/Cisco\ Secure\ Client.pkg
but I still get a "uses a deprecated pre-10.2 format (or uses a newer format but is invalid)." I didn't rename the pkg till after the flatten
Could I just pull the PKGs i need after its expanded and install them both with one policy or is that resources folder needed?
Posted on 03-06-2024 01:14 PM
I ended up leaving all the PKGs inside and just editing the distribution file to only include the parts I needed. That was able to run through self service without errors.
Posted on 06-17-2025 10:32 PM
Hi all,
Greetings from 2025! I just stumbled onto this thread. It would have been helpful to me a while back, but I built another solution. 🤣
Seeking to use JAMF Composer, I put together a procedure for putting your `choices.xml` and DMG into a package, and a modified `postinstall` that installs using the `choices.xml`.
https://github.com/atlauren/CiscoSecureClient-choices.xml-Composer-Jamf
Enjoy!
-Andrew
