07:47 AM
09:11 AM
All,
I've been tasked to come up with a quick way to get the same functionality of KnockKnock.py https://github.com/synack/knockknock into an extension attribute.
Knockknock.py is a script that has a "Who's There" output that contains a list of cron jobs, login items, startup items, KeXT files, launchD items, Launch Agents. login/out hooks, and browser extensions. I need a way to get these items into Casper for quick reporting.
In the past, Casper collected the unix binaries but it doesn't seem to gather that in 9. i'm sure with some work, i could use system_profiler to pull this info an EA, but was wondering if anyone had a suggestion on making this work?
I'd rather not push this script out to each device and have it create a local file.
Thoughts?
Posted on 12-12-2014 10:57 AM
I handed this off to one of my former interns @michaeldornisch, who builds robots on the weekends and once etched a company logo into the metal casing of a USB drive with a laser of his own design and he came up with the following to get this to work.
cd /tmp
mkdir knockknock
cd knockknock
curl -o k.zip -L https://github.com/synack/knockknock/archive/master.zip; unzip k.zip
cd knockknock-master
echo "<result>$(python knockknock.py -j)</result>"
cd /tmp
rm -rf knockknock
To make it a little more human readable, you can lose the -j in the python command between the results tags.
Don't know if anyone has a need for this, but if you do, here you go.
--M
cd /tmp
mkdir knockknock
cd knockknock
cd /tmp
rm -rf knockknock
--M
