Posted on 01-19-2024 02:17 AM
I am looking for a way to manage the settings to allow accessory (USB/Thunderbold).
In the System Preferences are these settings available:
Ask every time
Ask for new accessories
Automatically when unlocked
Always
But I didnt find any setting options in the following MDM command:
https://support.apple.com/guide/deployment/manage-accessory-access-depf8a4cb051/1/web/1.0
Is there a different way to set this option to "Ask every time" ?
Posted on 01-19-2024 02:39 AM
if you need to block connecting USB / Thunderbolt devices.. there is nothing in macOS / JAMF that provides this function. You'll need to look at 3rd party solutions.
Posted on 01-19-2024 04:24 AM
I dont want to block USB Devices.
I want to manage the setting. My target is that the user gets an requester each time a USB Device connects to the Mac.
Posted on 01-19-2024 02:25 PM
It can be managed by MDM..
The domain is com.apple.applicationaccess and the key is allowUSBRestrictedMode
More info : apple
If false, the system allows iOS devices to always connect to USB accessories while locked. On macOS, allows new USB and Thunderbolt accessories and SD cards to connect without authorization. If the system has Lockdown mode enabled, it ignores this value. Available in iOS 11.4.1 and later, and macOS 13 and later. Requires a supervised device in iOS.
Posted on 01-22-2024 12:15 AM
Well, that is the same like I referred to by the URL in my first post.
That setting allows only a permanent Yes or No.
I am looking for a way, that "always ask" enables.
Posted on 03-14-2024 08:52 AM
I am looking to do something similar but to always allow since it seems there is a bug in 14.4 causing usb issues. Did anyone find a solution ?
Posted on 06-24-2024 12:20 PM
Just like @A_Collins mentioned, the domain is: com.apple.applicationaccess
Here is the link to the JSON script you can upload to as a Custom Schema in Configuration Policy:
Just copy the JSON code and paste it in the Custom Schema section of your Configuration Policy. It has tons of settings you can configure, but all you need is the Allow USB Restricted Mode.
This is the only portion needed:
Set to FALSE if you want to allow USB accessories.
Posted on 07-23-2024 03:55 PM
So I did this in Jamf and pushed out the profile, but it's not working. I made it look exactly like you second screen shot and still no dice. When I plug in a USB device it still asks for permission, which I want to disable.
07-24-2024 12:13 AM - edited 07-24-2024 12:14 AM
@jcoombes did you try to create a Configuration Profile and to upload it into Jamf Pro?
I use "ProfileCreator" to create the Profile, then export and sign it before importing it into Jamf Pro:
Posted on 07-24-2024 09:12 AM
No, I used the Jamf Custom Schema and created it directly inside Jamf.
Posted on 03-31-2025 07:25 PM
I’ve found that this setting is no longer working. It used to work, but we’ve encountered numerous machines where it has been applied, preventing the network adapter from being used to log in. Even if you manage to log in, you are then unable to manually change the setting due to JAMF restricting changes.
It would be best to avoid applying any Configuration Profile for this setting.
Posted on 04-01-2025 12:33 AM
@eaititig that is the way Configuration Profiles work, they avoid changes from the User site.
To manage the use of USB Devices, I would use 3rd Party Tools like S1.
