Posted on 01-09-2025 09:58 PM
How can I disable the Help Apple Improve Search Item in the Spotlight Section of the System Settings?
I can't find anything in Configuration Profiles and didn't find something related in com.apple.Spotlight.plist in /Library/Preferences/ or ~/Library/Preferences/.
Posted on 01-09-2025 11:20 PM
Deploy the below Plist
com.apple.assistant.support
<key>Search Queries Data Sharing Status</key>
<integer>2</integer>
<key>Siri Data Sharing Opt-In Status</key>
Posted on 01-10-2025 12:11 AM
Implemented and works as it should. Thank you very much!
Posted on 04-01-2025 08:17 AM
I tried this and I cannot get this to work, do you setup a configuration profile?
Posted on 05-18-2025 09:31 PM
You have to configure a Configuration Profile in Jamf Pro as seen in the screenshot below.
