GlobalProtect 6.0.7 Portal Script
DrumBum213
Hey everyone. I was recently asked to upgrade our GlobalProtect to 6.0.7. After some extensive searching on JAMF Nation I was able to piece a good script together that will add your portal connection(s) to the install. Create your package and the following script...
sudo rm -f /Library/Preferences/com.paloaltonetworks.GlobalProtect.settings.plist
# Set the portal address for GlobalProtect
portalAddress="YOURCONNECTION"
# Modify PLIST to reflect the correct portal address.
echo '<?xml version="1.0" encoding="UTF-8"?><!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"><plist version="1.0"><dict><key>Palo Alto Networks</key><dict><key>GlobalProtect</key><dict><key>PanSetup</key><dict><key>Portal</key><string>'$portalAddress'</string><key>Prelogon</key><integer>0</integer></dict></dict></dict></dict></plist>' >> /Library/Preferences/com.paloaltonetworks.GlobalProtect.settings.plist
sudo rm -rf /Users/*/Library/Application Support/PaloAltoNetworks/GlobalProtect
sudo rm -rf /Users/*/Library/Preferences/com.paloaltonetworks.GlobalProtect*
sudo rm -rf /Users/*/Library/Preferences/PanGPS*
pkill -f GlobalProtect
@DrumBum213 FYI Palo Alto Networks has produced updated documentation on how to deploy Global Protect via Jamf Pro: https://docs.paloaltonetworks.com/globalprotect/10-1/globalprotect-admin/mobile-endpoint-management/...
jtrant
Can PAN GP 6.x now handle the preconfiguration of multiple portal URLs?
efil4xiN
Leaving here as it tripped me up for 10 mins. Run the script BEFORE the installation
