07:40 AM
07:02 AM
Just an odd question, I was going through our prestage enrollment options and I noticed there was an option for Privacy and FileVault, when I go into edit them I can select Privacy but FileVault is greyed out. Is FV being greyed out normal?
Edit: on J.Pro 10.6.0
Posted on 08-09-2018 08:19 AM
It greys out if you have any Config Profiles with FV-related payloads in them. It should skip the FV prompt in Setup Assistant as it basically hands off FV management to the JSS.
