Posted on 03-27-2025 02:50 AM
we recently acquired a Jamf Pro license and wanted to build a update ring for certain softwares.
Since Cisco Anyconnect is not available in Patch Management i thought i'll make a feature request.
Posted on 03-27-2025 07:14 AM
@HerrIT this is a good request.
If you want to request this I recommend going to https://ideas.jamf.com/ideas/PCAP-I-152 and voting for the request there to have Cisco AnyConnect added, which includes Cisco Secure Client.
Any new requests or voting on existing ideas all happen at https://ideas.jamf.com/ideas.
@BookMac is right. Title Editor would be a good idea to use. You can find more details here:
Setting up Title Editor in Jamf Pro
Manual Creation - Title Editor Documentation
Hopefully this will get you going. Feel free to reach out if you have any issues.
Your Jamf Success representative is also a helpful resource.
Posted on 03-27-2025 06:17 AM
you can use title editor to add Cisco Secure Client
Posted on 03-27-2025 06:48 AM
With my Jamf ID?
I mean do i login to Title Editor with my Jamf ID?
Posted on 03-31-2025 12:06 AM
I cant login with my Jamf ID in Title Editor. Did i miss something?
Posted on 03-28-2025 11:32 AM
If you use Cisco ISE management to manage your VPN, why not use that to deploy your upgrade? You can configure a update policy with the Cisco profile so when the user logs into the VPN client it will automatically update.
