Falcon repair script
ScottEKendall
Greetings Jamf Nation!
I have been woking on a more comprehensive Falcon repair script to assist in detecting and/or trying to repair any potential issues found in the sensors.  This is strictly a WIP and I would love to get everyone's feedback on ideas or items that I might have missed.  This script is borrowing heavily from Dan K Snelson, so kudos for him creating the original concept...I just want to take it a "one step further"...
#!/bin/zsh
# Written by: Scott Kendall
# Date Created: 01/21/2025
# Date Last Revised: 01/23/2025
# Borrowed heavily from @snelson: source code @ https://snelson.us/2023/03/crowdstrike-falcon-kickstart-0-0-2/
# Gobal "Common" variables (do not change these!)
export PATH=/usr/bin:/usr/local/bin:/bin:/usr/sbin:/sbin
SUPPORT_DIR="<your support log folder>"
LOG_DIR="${SUPPORT_DIR}/logs"
LOG_FILE="${LOG_DIR}/FalcanSensor.log"
LOG_STAMP=$(echo $(/bin/date +%Y%m%d))
falconBinary="/Applications/Falcon.app/Contents/Resources/falconctl"
falcanJAMFtrigger="crowdstrike"
exitCode="0"
# Functions
function create_log_directory ()
    # Ensure that the log directory and the log files exist. If they
    # do not then create them and set the permissions.
    # RETURN: None
	# If the log directory doesnt exist - create it and set the permissions
	[[ ! -d "${LOG_DIR}" ]] && /bin/mkdir -p "${LOG_DIR}"
	/bin/chmod 755 "${LOG_DIR}"
	# If the log file does not exist - create it and set the permissions
	[[ ! -f "${LOG_FILE}" ]] && /usr/bin/touch "${LOG_FILE}"
	/bin/chmod 644 "${LOG_FILE}"
function logMe ()
    # Basic two pronged logging function that will log like this:
    # 20231204 12:00:00: Some message here
    # This function logs both to STDOUT/STDERR and a file
    # The log file is set by the $LOG_FILE variable.
    # RETURN: None
    echo "${1}" 1>&2
    echo "$(/bin/date '+%Y-%m-%d %H:%M:%S'): ${1}" | tee -a "${LOG_FILE}"
function preflight_check ()
    # Pre-flight Check: Confirm script is running as root
    [[ $(id -u) -ne 0 ]] && {logMe "PRE-FLIGHT CHECK: This script must be run as root; exiting."; exit 1}
    # Pre-flight Check: Confirm CrowdStrike Falcon System Extension is running
    systemExtensionTest=$( systemextensionsctl list | grep -o "com.crowdstrike.falcon.Agent.*" | cut -f2- -d" " )
    if [[ -n "${systemExtensionTest}" ]]; then
        systemExtensionStatus="${systemExtensionTest}"
        systemExtensionStatus="Not Found"
        logMe "Falcon not installed: Loading policy from JAMF"
    logMe "CrowdStrike Falcon System Extension Status: ${systemExtensionStatus}"
    # Pre-flight Check: Complete
    logMe "PRE-FLIGHT CHECK: Complete"
function log_sensor_updates()
        logMe "Falcon Sensor Operational: ${1}"
        logMe "Updating inventory …"
        jamf recon
function connection_test()
    test=$("nc -vz ts01-b.cloudsink.net 443")
    [["${test}" == *"succedded!"* ]] && echo "true" || echo "false"
function load_sensor()
    echo $( ${falconBinary} load --verbose)
function load_jamf_policy ()
    jamf policy -trigger "${falcanJAMFtrigger}"
function get_agent_info ()
     echo $( $falconBinary stats agent_info 2>&1 )
# Program
preflight_check
exitCode="0"
# Process CrowdStrike Falcon System Extension Status
logMe "Processing System Extension Status …"
systemExtensionStatus=$(systemextensionsctl list | grep -o "com.crowdstrike.falcon.Agent.*" | cut -f2- -d" ")
# Check the extension status first and evaluate
case ${systemExtensionStatus} in
    *"[activated enabled]"* )
        logMe "CrowdStrike Falcon System Extension enabled"
        logMe "Validating Sensor Operation …"
        sensorOperationalStatus=$( get_agent_info ) #| awk '/Sensor operational:/{print $3}')
        # check for specific issues in regards to the status
        case ${sensorOperationalStatus:l} in
            *"true"* )
                # sensors are loaded and functioning correclty
                log_sensor_updates "${sensorOperationalStatus}"
            *"sensor has not loaded."* | *"sensor is unknown."* | *"sensor is unloaded."* )
                # Sensors are not loaded properly
                sensorOperationalStatus=$( load_sensor)
                logMe "Attempting to Load the Falcon Sensor"
            *"not licensed"* )
                # product is not licensed...perform a license command and then make sure that the sensors are loaded
                logMe "Attempting to License the Falcon Sensor"
                falconKickStartLicense=$( $falconBinary license "$( defaults read /Library/Managed\ Preferences/com.crowdstrike.falcon.plist ccid )" --noload --verbose)
                log_sensor_updates "${falconKickStartLicense}"
        esac
    *"uninstall on reboot"* )
        # It looks like a restart might be in order
        logMe "The system needs to be restarted for the sensor to load properly"
        exitCode="1"
    *"waiting for user"* )
        # it appears that everything is working OK, but the user needs to start doing "something"
        logMe "Falcon Sensor Status: ${sensorOperationalStatus}"
    "Not Found" )
        # Crowdstrike not found, so lets try to remove any previous install and try to reinstall it
        logMe "CrowdStrike Falcon System Extension NOT found: Attempting Re-installation"
        falconKickStartUninstall=$( ${falconBinary} uninstall -verbose )
        log_sensor_updates "${falconKickStartUninstall}"
        logMe "Re-installing CrowdStrike Falcon …"
        load_jamf_policy
        exitCode="1"
        # Catch all if we got a different error
        logMe "Attempting to kickstart Falcon Sensor …"
        falconKickStartLicense=$( ${falconBinary} license )
        logMe "Falcon Kickstart License Result: ${falconKickStartLicense}"
        falconKickStartLoad=$( load_sensor )
        logMe "Falcon Kickstart Load Result: ${falconKickStartLoad}"
        if [[ "${falconKickStartLoad}" == "Falcon sensor is loaded" ]]; then
            [[ "${sensorOperationalStatus}" == "true" ]] && logMe "Falcon Sensor Status: ${sensorOperationalStatus}"
            exitCode="1"
esac
logMe "Exit Code: ${exitCode}"
exit "${exitCode}"
2 REPLIES 2
mattjerome
I used to do something similar where I had an extension attribute that reported an error and if there was an error it went to a smart group that triggered a policy to uninstall and reinstall. That fixed 90% of issues.
Anyone looking to deploy, and or remove/remediate, CrowdStrike on Macs should really do themselves a favor and look at @franton's guide on scripting that process with the CS API :
https://richard-purves.com/2022/05/03/downloading-crowdstrike-via-api-for-fun-and-profit/
And the associated GitHub repo:
https://github.com/franton/Crowdstrike-API-Scripts?tab=readme-ov-file
