Enterprise Connect Stealing Focus
judeglenn
Hello,
We have run into an issue recently of Enterprise Connect stealing focus on users' Macs. Even if signed in correctly, the pop up will come up and steal the current focus from other apps. Hitting the close button makes it disappear for a while (sometimes only for a split second, other times for minutes) but then it pops back up. Current workaround is just having users minimize the app, but this is not ideal for multitasking in the sidebar.
Does anyone know of a resolution?
Josh
@josh.glenn What version of EC? I haven't seen that behavior with EC 2.0.5.
judeglenn
Thanks for the quick response @sdagley
We are on version 2.0.5
You might try asking in the #enterprise-connect channel of the MacAdmins Slack
