Discovery of Homebrew
robertliebsch
So I have used a script found here to push Homebrew out to folks. I'd like to verify that. Also, I'd like to find others who don't have it installed.
Smart groups doesn't support (that I can see) finding /usr/local/bin/brew
How would you approach this?
1 REPLY 1
@robertliebsch You'll want to create an Extension Attribute to determine if Homebrew is installed, and then use the results of that EA as your Smart Group Criteria. Here's an older thread that discusses how to do that: Home Brew and Collect Application Usage Information
