11:24 AM
05:45 AM
Is there a way, either under the Mobile Device Tab or the Users Tab to look up a Static User Group or a Smart User Group and quickly see what apps are assigned to that group? (either under Mobile or Users).
Posted on 02-21-2018 06:46 AM
There isn't a way to look that up easily. If you have direct access to the database, you can run a SQL query. See this post for more info.
https://www.jamf.com/jamf-nation/feature-requests/948/list-of-apps-scoped-by-mobile-device-group
I suggest you upvote it to get Jamf to implement this.
Posted on 02-21-2018 10:42 AM
if you click on a device record and go to the management tab you can see what device groups it is a part of and what apps are in scope for that device, which could answer that in a roundabout way...?
