Posted on 04-17-2025 12:43 AM
Is anyone else experiencing an issue where Configuration Profiles are being removed? Every morning, these profiles disappear from over 30 devices, and I can’t work out why. I’ve raised it with Jamf Support, but thought I’d ask here in case anyone else has come across something similar.
We’re running Jamf Pro Version 11.14.1, which we upgraded from 11.6 a couple of weeks ago. I’m not sure if the upgrade is the cause, as I didn’t notice this behaviour before the upgrade.
I'm seeing this under Management History section.
Posted on 04-17-2025 07:40 AM
The first thing you should check is scopes for the profiles. If you are using smart groups to scope the affected profiles, your Macs may have fallen out of those smart groups if they no longer fit the criteria defined for the smart groups.
Posted on 04-17-2025 10:49 PM
Check the Scope of this Profiles and check did this device was ever moved out of the smart group, check the criteria of the smart group ,
Posted on 04-22-2025 12:49 AM
The machines are showing in the Smart Groups and I've had a look at the scope of the configurations profile and it's being targeted correctly.
