Config Profiles Deploying but not Applying
WilliamDunn
We Seem to have developed a problem since upgrading to Jamf 11 that when we try to push out a Configuration profile to enable/disable an item in Privacy and Security the Config Profile lists as deployed, is appearing on the laptops list of Config Profile but absolutly nothing has changed in the Privacy and Security settings. For Example trying to set up the new Teams program with Folder Access the Config Profile is correct but nothing has changed on the device. Our Position is correct except no Alderaan.
@WilliamDunn Are you saying the profiles are not working with Jamf Pro 11, or just that there's no visual indication in the PPPC GUI there's no indication they're being set? PPPC settings applied via Configuration Profile have never been visible in the PPPC GUI in System Preferences/System Settings, this isn't new with Jamf Pro 11.
They're appearing but don't appear to be active so with Teams the Teams (Work or School) appears but is not enabled and is not having any effect.
Mattdjerome
What OS are you testing? This isn’t possible anymore with Ventura or Sonoma. I used to do it in Monterey.
williamaddis
If you are looking at the gui in System Settings to see that the slider is enabled you wouldn't see that if enabled via a config profile, only if the user manually enabled it.  The settings should still be functioning properly though. You shouldn't be getting the "Teams wants to access x folder" (or whatever setting you were trying to set).
