Posted on 03-28-2024 09:14 AM
Hello Jamf Community,
iam looking for a Script to uninstall the Cisco Client Silent.
I have a script that does it, but the Users will always get a Pop-Up Message that the Socket Filter needs Admin Permission. You can ignore the window, and it is uninstalled, but I would like to have it more clean.
Greetings TGD
Posted on 03-28-2024 09:32 AM
Are you running this script?
/opt/cisco/secureclient/bin/cisco_secure_client_uninstall.sh
Posted on 03-31-2024 06:41 PM
If you use the XML custom setup, this pop-up doesn't appear. Would highly recommend but takes some time to setup. https://docs.umbrella.com/umbrella-user-guide/docs/customize-macos-installation-of-cisco-secure-clie...
Otherwise, I had to make a script to make the user an admin, install the software, remove the components (thousand eyes, DART, etc...), and then demote the user admin rights. This way the user can at least use their credentials to accept or cancel out. We found an issue with the umbrella going this route, that the umbrella wasn't active until after the first time the user connected to the VPN.
04-01-2024 05:58 AM - edited 04-01-2024 06:24 AM
I used Suspicious Package https://mothersruin.com/software/SuspiciousPackage/ to copy out uninstall script(s) from the pkg installer(s). To make back up "clean up" removal policies when the normal process (invoke the uninstall script) fails.
Here's the VPN/VPN Socket removal script from the pkg (but won't remove the other module(s) from 5.1.2.42
INSTPREFIX="/opt/cisco/secureclient"
BINDIR="${INSTPREFIX}/bin"
PLUGINDIR="${BINDIR}/plugins"
LIBDIR="${INSTPREFIX}/lib"
PROFDIR="${INSTPREFIX}/vpn/profile"
MGMTPROFDIR="${INSTPREFIX}/vpn/profile/mgmttun"
SCRIPTDIR="${INSTPREFIX}/vpn/script"
HELPDIR="${INSTPREFIX}/help"
KEXTDIR="/Library/Application Support/Cisco/Cisco Secure Client"
APPDIR="/Applications/Cisco"
GUIAPP="Cisco Secure Client.app"
NWEXT_KDF_APP="Cisco Secure Client - Socket Filter.app"
UNINSTALLER="Uninstall Cisco Secure Client.app"
LAUNCHD_DAEMON_DIR="/Library/LaunchDaemons"
LAUNCHD_DAEMON_VPNAGENT_FILE="com.cisco.secureclient.vpnagentd.plist"
LAUNCHD_AGENT_DIR="/Library/LaunchAgents"
LAUNCHD_AGENT_GUI_FILE="com.cisco.secureclient.gui.plist"
LAUNCHD_AGENT_NOTIFICATION_FILE="com.cisco.secureclient.vpn.notification.plist"
ACMANIFESTDAT="${INSTPREFIX}/VPNManifest.dat"
VPNMANIFEST="ACManifestVPN.xml"
LOGDIR="/var/log/secureclient"
UNINSTALLLOG="${LOGDIR}/csc_vpn_uninstall.log"
KDFDIR="${INSTPREFIX}/kdf"
KDF_BINDIR="${KDFDIR}/bin"
KDF_LIBDIR="${KDFDIR}/lib"
INSTALL_DIR="${INSTPREFIX}/install"
COMPONENT_DIR="${INSTALL_DIR}/component"
DEPENDENCY_DIR="${INSTALL_DIR}/dependency"
SERVICE_APP="Cisco Secure Client - AnyConnect VPN Service.app"
CSC_VPN_PACKAGE_ID=com.cisco.pkg.anyconnect.vpn
# When AnyConnect VPN is being uninstalled, the plugins for
# modules that depend on VPN must also be removed. This is
# done to ensure that AnyConnect VPN and dependent modules
# have same version.
VPN_DEPENDENT_FILELIST=("${PLUGINDIR}/libacampctrl.dylib" \
"${PLUGINDIR}/libacampshim.dylib" \
"${PLUGINDIR}/libacisectrl.dylib" \
"${PLUGINDIR}/libaciseshim.dylib" \
"${PLUGINDIR}/libacnvmctrl.dylib" \
"${PLUGINDIR}/libacswgplugin.dylib" \
"${PLUGINDIR}/libacumbrellaapi.dylib" \
"${PLUGINDIR}/libacumbrellactrl.dylib" \
"${PLUGINDIR}/libacumbrellaplugin.dylib" \
"${PLUGINDIR}/csc_sfpuiplugin.dylib")
# Array of files to remove
FILELIST=("${BINDIR}/vpnagentd" \
"${BINDIR}/vpn_uninstall.sh" \
"${BINDIR}/cisco_secure_client_uninstall.sh" \
"${BINDIR}/vpn" \
"${BINDIR}/vpnmgmttun" \
"${BINDIR}/acextwebhelper" \
"${BINDIR}/acinstallhelper" \
"${BINDIR}/vpndownloader.app" \
"${BINDIR}/UpdateComponentManifest.json" \
"${BINDIR}/manifesttool" \
"${BINDIR}/manifesttool_vpn" \
"${BINDIR}/SetUIDTool_vpn" \
"${BINDIR}/Cisco Secure Client - Web Browser.app" \
"${INSTPREFIX}/AnyConnectLocalPolicy.xsd" \
"${INSTPREFIX}/gui_keepalive" \
"${INSTPREFIX}/OpenSource.html" \
"${INSTPREFIX}/update.txt" \
"${INSTPREFIX}/${VPNMANIFEST}" \
"${LIBDIR}/libacciscossl.dylib" \
"${LIBDIR}/libacciscocrypto.dylib" \
"${LIBDIR}/libaccurl.4.dylib" \
"${LIBDIR}/libboost_atomic.dylib" \
"${LIBDIR}/libboost_filesystem.dylib" \
"${LIBDIR}/libboost_system.dylib" \
"${LIBDIR}/libboost_thread.dylib" \
"${LIBDIR}/libboost_date_time.dylib" \
"${LIBDIR}/libboost_chrono.dylib" \
"${LIBDIR}/libvpncommon.dylib" \
"${LIBDIR}/libvpncommoncrypt.dylib" \
"${LIBDIR}/libvpnapi.dylib" \
"${LIBDIR}/libacruntime.dylib" \
"${PLUGINDIR}/libvpnipsec.dylib" \
"${PLUGINDIR}/libacfeedback.dylib" \
"${PLUGINDIR}/libacwebhelper.dylib" \
"${PLUGINDIR}/libvpnapishim.dylib" \
"${PLUGINDIR}/libacdownloader.dylib" \
"${PROFDIR}/AnyConnectProfile.xsd" \
"${MGMTPROFDIR}/AnyConnectProfile.xsd" \
"${LAUNCHD_DAEMON_DIR}/${LAUNCHD_DAEMON_VPNAGENT_FILE}" \
"${LAUNCHD_AGENT_DIR}/${LAUNCHD_AGENT_GUI_FILE}" \
"${LAUNCHD_AGENT_DIR}/${LAUNCHD_AGENT_NOTIFICATION_FILE}" \
"${APPDIR}/${GUIAPP}" \
"${APPDIR}/${UNINSTALLER}" \
"${KEXTDIR}/acsock.kext" \
"${KDFDIR}/gui_kext.plist" \
"${BINDIR}/Cisco Secure Client - Notification.app" \
"${KDF_BINDIR}/acsocktool" \
"${KDF_LIBDIR}/libacsock_api_common.dylib" \
"${COMPONENT_DIR}/acsock64.json" \
"${COMPONENT_DIR}/acsock64-kext.json" \
"${COMPONENT_DIR}/acsock-arm64.json" \
"${COMPONENT_DIR}/acsock-arm64-kext.json" \
"${DEPENDENCY_DIR}/vpn_manifest.json" \
${VPN_DEPENDENT_FILELIST[@]})
# Create log directory if not exist
if [ ! -d ${LOGDIR} ]; then
mkdir -p ${LOGDIR} >/dev/null 2>&1
echo "Uninstalling Cisco Secure Client..."
echo "Uninstalling Cisco Secure Client..." > "${UNINSTALLLOG}"
echo `whoami` "invoked $0 from " `pwd` " at " `date` >> "${UNINSTALLLOG}"
# Check for root privileges
if [ `whoami` != "root" ]; then
echo "Sorry, you need super user privileges to run this script."
echo "Sorry, you need super user privileges to run this script." >> "${UNINSTALLLOG}"
exit 1
IS_UPGRADE=${1-false}
# update the VPNManifest.dat
echo "${BINDIR}/manifesttool -x ${INSTPREFIX} ${INSTPREFIX}/${VPNMANIFEST}" >> "${UNINSTALLLOG}"
${BINDIR}/manifesttool -x ${INSTPREFIX} ${INSTPREFIX}/${VPNMANIFEST} >> "${UNINSTALLLOG}"
OS_VER_MAJOR=$(sw_vers -productVersion | awk -F. '{ print $1; }')
OS_VER_MINOR=$(sw_vers -productVersion | awk -F. '{ print $2; }')
MYUID=`echo "show State:/Users/ConsoleUser" | scutil | awk '/kCGSSessionUserIDKey/ { print $3 }'`
# Stop the GUI app launch agent if it exists
if [ -e ${LAUNCHD_AGENT_DIR}/${LAUNCHD_AGENT_GUI_FILE} ] ; then
echo "Stopping GUI launch agent..." >> "${UNINSTALLLOG}"
logger "Stopping the GUI launch agent..."
echo "launchctl bootout gui/${MYUID} ${LAUNCHD_AGENT_DIR}/${LAUNCHD_AGENT_GUI_FILE}" >> "${UNINSTALLLOG}"
launchctl bootout gui/${MYUID} ${LAUNCHD_AGENT_DIR}/${LAUNCHD_AGENT_GUI_FILE} >> "${UNINSTALLLOG}" 2>&1
# Stop the Notification app launch agent if it exists
if [ -e ${LAUNCHD_AGENT_DIR}/${LAUNCHD_AGENT_NOTIFICATION_FILE} ] ; then
echo "Stopping Notification launch agent..." >> "${UNINSTALLLOG}"
logger "Stopping the Notification launch agent..."
echo "launchctl bootout gui/${MYUID} ${LAUNCHD_AGENT_DIR}/${LAUNCHD_AGENT_NOTIFICATION_FILE}" >> "${UNINSTALLLOG}"
launchctl bootout gui/${MYUID} ${LAUNCHD_AGENT_DIR}/${LAUNCHD_AGENT_NOTIFICATION_FILE} >> "${UNINSTALLLOG}" 2>&1
# Stop the VPN agent launch daemon if it exists
if [ -e ${LAUNCHD_DAEMON_DIR}/${LAUNCHD_DAEMON_VPNAGENT_FILE} ] ; then
echo "Stopping agent..." >> "${UNINSTALLLOG}"
logger "Stopping the VPN agent..."
echo "launchctl bootout system ${LAUNCHD_DAEMON_DIR}/${LAUNCHD_DAEMON_VPNAGENT_FILE}" >> "${UNINSTALLLOG}"
launchctl bootout system ${LAUNCHD_DAEMON_DIR}/${LAUNCHD_DAEMON_VPNAGENT_FILE} >> "${UNINSTALLLOG}" 2>&1
# Stop the AnyConnect VPN Service app
echo "Stopping AnyConnect VPN Service..." >> "${UNINSTALLLOG}"
logger "Stopping AnyConnect VPN Service..."
osascript -e "quit app \"${SERVICE_APP}\""
pkill -x "${SERVICE_APP}"
# Unregister services
echo "Unregistering AnyConnect VPN Service..." >> "${UNINSTALLLOG}"
logger "Unregistering AnyConnect VPN Service..."
sudo -u \#${MYUID} open -W -a "${BINDIR}/${SERVICE_APP}" --args uninstall
# grep pattern to skip processes that shouldn't be considered as "Cisco Secure Client" related processes.
SKIPPROCS="grep|installer|preinstall|vpn_uninstall|cisco_secure_client_uninstall|${UNINSTALLER}"
# ensure that the agent, gui and cli are not running - show no mercy
OURPROCS=`ps -A -o pid,command | egrep "vpnagentd|(${INSTPREFIX}/bin)|(Cisco Secure Client)" | egrep -v "${SKIPPROCS}" | awk '{print $1}'`
if [ -n "${OURPROCS}" ] ; then
for DOOMED in ${OURPROCS}; do
echo Killing `ps -A -o pid,command -p ${DOOMED} | grep ${DOOMED} | egrep -v 'ps|grep'` >> "${UNINSTALLLOG}"
kill -KILL ${DOOMED} >> "${UNINSTALLLOG}" 2>&1
# Revert the system pf.conf file updates performed during install, unless this uninstall is part of an upgrade.
if [ "x${IS_UPGRADE}" != "xtrue" ]; then
echo "Reverting pf.conf changes" >> "${UNINSTALLLOG}"
${BINDIR}/acinstallhelper -pfConfUpdate -revert
echo "Skip reverting pf.conf changes during upgrade" >> "${UNINSTALLLOG}"
# Remove the AnyConnect VPN Service app, unless this is part of an upgrade
echo "rm -rf ${BINDIR}/${SERVICE_APP}" >> "${UNINSTALLLOG}"
rm -rf "${BINDIR}/${SERVICE_APP}" >> "${UNINSTALLLOG}"
echo "Skip removing AnyConnect VPN Service app during upgrade" >> "${UNINSTALLLOG}"
# Notify KDF upgrade start.
# TODO: REVISIT ONCE THE KDF PACKAGE IS AVAILABLE.
if [ "x${IS_UPGRADE}" = "xtrue" ]; then
echo "Notifying KDF upgrade start" >> "${UNINSTALLLOG}"
${KDF_BINDIR}/acsocktool -us >> "${UNINSTALLLOG}"
# unload the acsock if it is still loaded by the system
ACSOCKLOADED=`kextstat | grep acsock`
if [ ! "x${ACSOCKLOADED}" = "x" ]; then
echo "Unloading {KEXTDIR}/acsock.kext" >> "${UNINSTALLLOG}"
kextunload "${KEXTDIR}/acsock.kext" >> "${UNINSTALLLOG}" 2>&1
echo "${KEXTDIR}/acsock.kext unloaded" >> "${UNINSTALLLOG}"
# The network extension KDF is installed regardless of OS version, but only used on macOS 10.16+.
if [[ "$OS_VER_MAJOR" -ge 11 ]] || [[ "$OS_VER_MINOR" -ge 16 ]] ; then
# Deactivate the network extension KDF if not upgrade. For upgrade, the KDF app will simply be
# upgraded to avoid deactivation/activation approval prompts.
ACSOCKEXTACTIVE=`systemextensionsctl list | grep acsockext`
if [ ! "x${ACSOCKEXTACTIVE}" = "x" ]; then
echo "Deactivating network extension acsockext" >> "${UNINSTALLLOG}"
# Need to run as logged in user, as user needs to authorize the extension deactivation.
sudo -u \#${MYUID} "${APPDIR}/${NWEXT_KDF_APP}/Contents/MacOS/Cisco Secure Client - Socket Filter" -deactivateExt >> "${UNINSTALLLOG}"
echo "Network extension acsockext deactivated" >> "${UNINSTALLLOG}"
echo "Skip deactivating of network extension acsockext during upgrade" >> "${UNINSTALLLOG}"
# Remove the network extension KDF app.
echo "rm -rf ${APPDIR}/${NWEXT_KDF_APP}" >> "${UNINSTALLLOG}"
rm -rf "${APPDIR}/${NWEXT_KDF_APP}" >> "${UNINSTALLLOG}"
# Remove only those files that are installed for AnyConnect VPN,
# or are dependent on AnyConnect VPN being installed.
INDEX=0
while [ $INDEX -lt ${#FILELIST[@]} ] ; do
echo "rm -rf "${FILELIST[${INDEX}]}"" >> "${UNINSTALLLOG}"
let "INDEX = $INDEX + 1"
# Remove the kdf/lib directory
if [ -e ${KDF_LIBDIR} ] ; then
echo "rm -rf "${KDF_LIBDIR}"" >> "${UNINSTALLLOG}"
rm -rf "${KDF_LIBDIR}" >> "${UNINSTALLLOG}" 2>&1
# Remove the kdf directory if it is empty
if [ -e ${KDFDIR} ] ; then
if [ ! -z `find "${KDFDIR}" -prune -empty` ] ; then
echo "rm -df "${KDFDIR}"" >> "${UNINSTALLLOG}"
rm -df "${KDFDIR}" >> "${UNINSTALLLOG}" 2>&1
# Since modules that are NOT dependent on AnyConnect VPN can be
# present (even after VPN is uninstalled), remove the "plugins"
# directory only if it is NOT empty.
if [ -e ${PLUGINDIR} ] ; then
if [ ! -z `find "${PLUGINDIR}" -prune -empty` ] ; then
echo "rm -rf "${PLUGINDIR}"" >> "${UNINSTALLLOG}"
rm -rf "${PLUGINDIR}" >> "${UNINSTALLLOG}" 2>&1
# Remove Disable VPN Profile unless an upgrade is in progress
echo "rm -rf \"${PROFDIR}/VPNDisable_ServiceProfile.xml\"" >> "${UNINSTALLLOG}"
rm -rf "${PROFDIR}/VPNDisable_ServiceProfile.xml"
# Remove the bin directory if it is empty
if [ -e ${BINDIR} ] ; then
if [ ! -z `find "${BINDIR}" -prune -empty` ] ; then
echo "rm -df "${BINDIR}"" >> "${UNINSTALLLOG}"
rm -df "${BINDIR}" >> "${UNINSTALLLOG}" 2>&1
# Only remove the Application directory if it is empty
if [ ! -z `find "${APPDIR}" -prune -empty` ] ; then
echo "rm -rf "${APPDIR}"" >> "${UNINSTALLLOG}"
rm -rf "${APPDIR}" >> "${UNINSTALLLOG}" 2>&1
# Remove the lib directory if it is empty
if [ -e ${LIBDIR} ] ; then
if [ ! -z `find "${LIBDIR}" -prune -empty` ] ; then
echo "rm -df "${LIBDIR}"" >> "${UNINSTALLLOG}"
rm -df "${LIBDIR}" >> "${UNINSTALLLOG}" 2>&1
# Remove the script directory if it is empty
if [ -e ${SCRIPTDIR} ] ; then
if [ ! -z `find "${SCRIPTDIR}" -prune -empty` ] ; then
echo "rm -df "${SCRIPTDIR}"" >> "${UNINSTALLLOG}"
rm -df "${SCRIPTDIR}" >> "${UNINSTALLLOG}" 2>&1
# Remove the help directory if it is empty
if [ -e ${HELPDIR} ] ; then
if [ ! -z `find "${HELPDIR}" -prune -empty` ] ; then
echo "rm -df "${HELPDIR}"" >> "${UNINSTALLLOG}"
rm -df "${HELPDIR}" >> "${UNINSTALLLOG}" 2>&1
# Remove the management profile directory if it is empty
if [ -e ${MGMTPROFDIR} ] ; then
if [ ! -z `find "${MGMTPROFDIR}" -prune -empty` ] ; then
echo "rm -df "${MGMTPROFDIR}"" >> "${UNINSTALLLOG}"
rm -df "${MGMTPROFDIR}" >> "${UNINSTALLLOG}" 2>&1
# Remove the profile directory if it is empty
if [ -e ${PROFDIR} ] ; then
if [ ! -z `find "${PROFDIR}" -prune -empty` ] ; then
echo "rm -df "${PROFDIR}"" >> "${UNINSTALLLOG}"
rm -df "${PROFDIR}" >> "${UNINSTALLLOG}" 2>&1
# Remove the install directory/subdirectories if empty.
if [ -e ${COMPONENT_DIR} ] ; then
if [ ! -z `find "${COMPONENT_DIR}" -prune -empty` ] ; then
echo "rm -df "${COMPONENT_DIR}"" >> "${UNINSTALLLOG}"
rm -df "${COMPONENT_DIR}" >> "${UNINSTALLLOG}" 2>&1
if [ -e ${DEPENDENCY_DIR} ] ; then
if [ ! -z `find "${DEPENDENCY_DIR}" -prune -empty` ] ; then
echo "rm -df "${DEPENDENCY_DIR}"" >> "${UNINSTALLLOG}"
rm -df "${DEPENDENCY_DIR}" >> "${UNINSTALLLOG}" 2>&1
if [ -e ${INSTALL_DIR} ] ; then
if [ ! -z `find "${INSTALL_DIR}" -prune -empty` ] ; then
echo "rm -df "${INSTALL_DIR}"" >> "${UNINSTALLLOG}"
rm -df "${INSTALL_DIR}" >> "${UNINSTALLLOG}" 2>&1
# remove installer receipt
pkgutil --forget ${CSC_VPN_PACKAGE_ID} >> "${UNINSTALLLOG}" 2>&1
echo "Successfully removed Cisco Secure Client from the system." >> "${UNINSTALLLOG}"
Posted on 06-25-2024 08:13 AM
Hello,
Any update ?
I Have exactly the same problem
Regards
Posted on 10-22-2024 02:18 AM
I get the same, yes. anyone found a fix?
Posted on 10-22-2024 06:39 AM
I do this... https://docs.umbrella.com/umbrella-user-guide/docs/customize-macos-installation-of-cisco-secure-clie...
No prompt or anything and customize what gets installed. The scripting method, to me in this case, is not worth the effort.
Posted on 10-22-2024 06:43 AM
To be clear, this is to install a current version, and it overwrite an older version automatically.
Posted on 10-22-2024 07:47 AM
This was for uninstalling Cisco Secure Client.
However, i've added a command to disable System extension and now it works, it does it silently:
sudo '/Applications/Cisco/Cisco Secure Client - Socket Filter.app/Contents/MacOS/Cisco Secure Client - Socket Filter' -deactivateExt
sudo /opt/cisco/secureclient/bin/cisco_secure_client_uninstall.sh
Hope this will help others as well
Posted on 04-07-2025 01:53 PM
You should be able to change the extension attribute for the system extension from Allowed System Extensions to Removable System Extensions. That will allow you to run the removal script via Jamf and it will remove the program without asking for admin rights to adjust the System Extension. https://www.cisco.com/c/en/us/td/docs/security/vpn_client/anyconnect/Cisco-Secure-Client-5/admin/gui...
I am still trying to figure out how to silently uninstall Cisco Secure Client - DART
Posted on 04-07-2025 01:54 PM
Sorry, I said extension attribute, I should have said configuration profile.
Posted on 04-08-2025 11:37 AM
DART can be silently uninstalled by running /opt/cisco/secureclient/bin/dart_uninstall.sh
Posted on 04-08-2025 11:43 AM
What I use, in case it helps:
/opt/cisco/secureclient/bin/amp_uninstall.sh
/opt/cisco/secureclient/bin/iseposture_uninstall.sh
/opt/cisco/secureclient/NVM/bin/nvm_uninstall.sh
/opt/cisco/secureclient/bin/umbrella_uninstall.sh
/opt/cisco/secureclient/bin/zta_uninstall.sh
### Uninstall Duo Desktop and Duo Device Health
/Applications/Duo\ Desktop.app/Contents/Library/LaunchServices/com.duosecurity.UninstallDuoDeviceHealth
/Applications/Duo\ Device\ Health.app/Contents/Library/LaunchServices/com.duosecurity.UninstallDuoDeviceHealth
### Uninstall ThousandEyes Agent
/Applications/Cisco/Cisco\ Secure\ Client\ -\ ThousandEyes\ Endpoint\ Agent.app/Contents/Resources/uninstall.sh
Posted on 04-08-2025 11:57 AM
Forgot, that if you're updating to Cisco Secure Client 5.1.8.122, the Duo Desktop won't go away for me. So I dragged the package in Composer and deleted Duo Desktop, then re-packaged. Yes, you can do the XML way, but this worked for me too.
Posted on 04-10-2025 07:55 AM
You have to add a Removable System Extension under "System Extensions" Menu.
