01:28 PM
07:30 AM
I'm having trouble getting Outset to work.
I deployed the outset package to a test computer and placed a bash script in the login-privileged-every directory but it does't run.
I've checked ownership and permissions and as far as I can tell there isn't anything I'm missing.
Here's some screenshots:
I'd appreciate any help getting this solved.
Posted on 05-11-2019 03:56 PM
I'd start with the log and go from there. Not clear if you are using the $3 for the user or not, but I never have as the folder dictates the frequency
Posted on 05-11-2019 08:29 PM
In the console app you should see an outset log under ~/Library/ if it’s a launch agent, /var/log if it’s privileged. I started there when I first set up outset.
