Autopkgr: FAIL_RECIPES_WITHOUT_TRUST_INFO Expecting value: line 2 column 1 (char1) Failed.
cdlp2043
I'm having issues with uploading to JAMF. Getting the error below.
WARNING: com.github.autopkg.grahampugh-recipes.jamf.zoom.us-pkg-upload is missing trust info and FAIL_RECIPES_WITHOUT_TRUST_INFO is not set. Proceeding...
Expecting value: line 2 column 1 (char 1)
Failed.
Any ideas on what could be causing this, and how to fix it?
Thanks.
6 REPLIES 6
@cdlp2043 Did the upload ever work?
cdlp2043
@sdagley Nope. Only locally creating the pkg.
@cdlp2043 I can't use package uploads in my environment, so not entirely sure what would trigger that error, but did you create an override for the definition, or are you trying to run the original definition itself? If the latter try creating an override.
SMR1
I'm using the below recipe and it uploads to jamf and I don't get the trust error
cdlp2043
@SMR Do you leverage SSO on you JAMF Portal? Because we do.
SMR1
We don't do SSO for logging on to the portal.
